Author Topic: 2013 with .NET 4.5  (Read 3252 times)
2013 with .NET 4.5
« on: August 01, 2012, 05:24:50 AM »
If you have 2013 installed and are thinking of installing the .NET framework 4.5 preview ; don't.
Simarly, if you have 4.5 installed don't bother installing 2013.
There is a compatibility issue between the 2.
AutoDesk are working on a resolution.
Uninstall 4.5 and reinstall .NET 4.0 in order for AutoCAD 2013 to run.
Regards
Kerry.
added:
One of the benefits of sending Customer Error Reporting (CER's) is that sometime the problem gets solved.
Symptoms.
Crashing on closing ( reproducible )
Crashing on some Dialog use. ( reproducible )
Crashing after a sequence of commands.
« Last Edit: August 01, 2012, 05:34:45 AM by Kerry »
kaefer
Re: 2013 with .NET 4.5
« Reply #1 on: August 01, 2012, 08:49:35 AM »
Symptoms.
Yep, but is it really that bad, apart from not updating the MRU list?
Care to be more specific?
« Reply #2 on: August 01, 2012, 07:15:05 PM »
Symptoms.
I assume that's a rhetorical question.
Appload dialog.
Layer command
Several Ribbon selections.
Sometimes just pure random lucky dip.
Regards
« Reply #3 on: September 28, 2012, 03:32:44 AM »
Recent testing with AutoCAD 2013 SP1.1 with .NET Framework 4.5 installed seem to indicate that any issues have been resolved.
Compiling with VS2012 to use .net 4.0 has not been a problem.
huiz
  • Certified Prof C3D
« Reply #4 on: September 28, 2012, 08:54:01 AM »
Symptoms.
Indeed, closing the application was intended anyway, so why not with a crash ;-)
