Author Topic: Proper use of S::STARTUP  (Read 11355 times)
« on: December 02, 2009, 08:17:20 PM »
Was just a bit perplexed over the correct use of this function, I've seen it used in many different ways, in the VLIDE help files and also on the forums - especially in the loading of dll's and VBA.
But I wondered if some of you experts here could properly explain to me how exactly it should be used, and for what purpose?
This question stems from a question posed over at CADTutor, and it got me thinking (and doubting)...
Many thanks in advance for your time,
Lee
Re: Proper use of S::STARTUP
« Reply #1 on: December 02, 2009, 08:39:48 PM »
S::STARTUP is probably a legacy throwback to pre-A2k. Although I still use it for loading some applications at startup and setting variables required for our working environment, there really isn't much else it is needed for. Of course the opinions will vary widely.
Lets just think about it for a minute ... S::STARTUP is executed whenever the first drawing is opened, unless you load it in each drawing. It then executes whatever functions you have programmed it to do.
So what might you want to do? Well, you might want to set things like limits, create layers, load linetypes, set variables etc ...
Ok, cool ... except most of that can be done within your template ...
Well, there is the possibility of having it autoload other lisp, vba and arx files ... except that can be done very easily in the startup suite (except, don't forget the startup suite is different for each profile)
Ok, maybe you want to autoexecute some of your lisps at startup ... ok, but that can be done within the lisp file itself ... i.e. (C:MYLISP)
Well .. then really there isn't anything that S::STARTUP can do for you that you cannot do in other ways ... however, I find it is still much simpler to utilize, especially considering the workspaces, profiles, templates etc. that can be changed and used by the person behind the keyboard. By using S::STARTUP you will be reasonably sure that no matter what profile is being used, no matter what menu, workspace or template is loaded, this function will be executed at least the first time a drawing is opened.
At one of my previous jobs, we used it exclusively to track drawing usage utilizing acadlspasdoc and acad.lsp to load it into each drawing.
So the "proper" use could be debated and you will likely find many people who use it as who don't ... kinda like in vba
sub startup()
'do stuff
end sub
it runs when loaded, but many people don't use it.
alanjt
  • Standby for witty remark...
« Reply #2 on: December 02, 2009, 08:59:06 PM »
Mark, you make me LoL.
Dropbox
SteveK
« Reply #3 on: December 02, 2009, 09:11:36 PM »
So the way I understand it, suppose (as in the current case on cadtutor) we want to use the NETLOAD command.
The options are:
  • We can either create a lisp with the command in it and add it to the startup suite
  • Or add it to S::STARTUP in say acaddoc.lsp
  • We can't directly add the command to ACADDOC because it loads before the drawing loads.
And adding it to the startup suite means it will only be there for that person. So if you were on a network the best (only) method is with S:STARTUP... :?
« Reply #4 on: December 02, 2009, 09:21:47 PM »
For a .NET dll I'd consider 2 options
Partial menu  .MNL file
Demand loading settings in the registry. (preferred)
SteveK
« Reply #5 on: December 02, 2009, 09:36:39 PM »
Thanks. I'd have to read up on implementation with an .mnl file. And registry, well I've always been scared to touch the registry (Microsoft warnings have got to me  :police:), and besides, it always seems like it'd be a big effort if you want to remove it again (compared to just removing it from the startup suite)?
So why would you recommend the registry way?
« Last Edit: December 02, 2009, 09:53:03 PM by steve.k »
« Reply #6 on: December 02, 2009, 10:04:49 PM »
This works for me ..... a simple autoload defined in the partial menu MNL
only loads the .NET dll when needed, so startup time in minimised ( similar to demand loading)
(defun c:CMD1 ()
  ;;// Codehimbelonga kwb@theSwamp 20070509
  ;;(findfile  "F:\\_VS2008Projects\\Projects\\ACAD-Managed\\CsMgdAcad-ColorLab\\bin\\Release\\CsMgdAcad-ColorLab.dll")
  (command
    "_NETLOAD"
  (command "CMD1")
Command: cmd1
Concept Code For AC2008, MSVS2005 :: kwb@theSwamp 20070509 ->> ...
<dll netloads and program runs first instance>
Command: CMD1
<program runs subsequent instances>
Regards
« Last Edit: December 02, 2009, 10:15:10 PM by Kerry Brown »
SteveK
« Reply #7 on: December 02, 2009, 10:41:22 PM »
Just to correct myself I just added (command "_CIRCLE" "0,0" "10") into my acaddoc.lsp file and ran autocad and it drew it. So a reason for S::STARTUP is not to run commands. Then what is the difference, I might as well add commands straight to acaddoc.lsp?   :|
SteveK
« Reply #8 on: December 02, 2009, 10:49:16 PM »
And Kerry (B) I'm lost with regards the partial menu MNL. First time I've really heard about it and autocad help file seems to talk about something else (about menu's  :-)), is there a tut around for what you are suggesting?
« Reply #9 on: December 02, 2009, 10:52:22 PM »
From Help
Also, if you use the command function in an acad.lsp or .mnl file, it should be called only from within a defun statement. Use the S::STARTUP function to define commands that need to be issued immediately when you begin a drawing session.
You can define an S::STARTUP function to perform any needed setup operations after the drawing is initialized.
The startup LISP files (acad.lsp, acaddoc.lsp, and MNL) are all loaded into memory before the drawing is completely initialized. Typically, this does not pose a problem, unless you want to use the command function, which is not guaranteed to work until after a drawing is initialized.
If the user-defined function S::STARTUP is included in an acad.lsp, acaddoc.lsp, or MNL file, it is called when you enter a new drawing or open an existing drawing. Thus, you can include a definition of S::STARTUP in the LISP startup file to perform any setup operations.
cadabyss
« Reply #10 on: December 02, 2009, 10:53:05 PM »
One benefit of using a s::startup function vs. acad.lsp or acaddoc.lsp is that s::startup runs after the drawing is loaded.  So s::startup could be used to setup the drawing to company standards for example.
A second benefit, is it provides one standard function which different third party developers can plug-into to initialize their routines.   Say you have a third party app called "QuickDraw" for example, and another third party app called "SymbolLib", they each could append to the s::startup function to load their initializing code.  Note that to append to any function during runtime, the function needs to be created with defun-q and not defun.
« Reply #11 on: December 02, 2009, 10:56:13 PM »
A partial menu is simply a secondary menu ... nothing special ... I use them so that I don't need to edit the ACAD.MNL.
The function I posted could be defined in ANY file that autoCAD loads into menory at startup/initialisation.
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS73099cc142f4875513fb5cd10c4aa30d6b-7f62.htm,topicNumber=d0e399760
« Last Edit: December 02, 2009, 10:59:25 PM by Kerry Brown »
SteveK
« Reply #12 on: December 02, 2009, 11:05:58 PM »
Aside: Ah!  8-) I was thinkin it had some special feature for starting up dll's!  :roll:
Re: S::STARTUP. That's shedding more light on it, thanks Steve, Kerry, Keith.
I can get away with drawing circles before the drawing has fully loaded, but say for big lisps with dialog boxes it would be better (likely essential) to have the drawing already loaded before proceeding with a program.
« Last Edit: December 02, 2009, 11:20:07 PM by steve.k »
« Reply #13 on: December 02, 2009, 11:58:19 PM »
I don't understand the circle reference and 'getting away' with stuff.
Your stated objective was to netload a dll. Have you tried the 'autoload/selfdefining' method I posted ?
SteveK
« Reply #14 on: December 03, 2009, 12:38:01 AM »
Your code works. Sorry I didn't say that very well, I was just saying it as a statement to try sum it all up. I.E. As I understand it if someone wanted to do something simple (eg draw circles) at startup they could just plug it straight into acaddoc, but for big lisps the S::STARTUP method is preferred and sometimes necessary as the drawing will be already loaded. (basically just repeating what Steve Doman said)
« Last Edit: December 03, 2009, 12:42:05 AM by steve.k »
