Author Topic: Break Line at Point or Intersection  (Read 5311 times)
GDF
« on: August 17, 2009, 03:32:26 PM »
Doe anyone have a routine to break a line at point or intersection. The routine below no longer woks for 2010
(defun BPIT  (/ P1 P2)
  (setq OSM (GETVAR "OSMODE"))
  (setvar "OSMODE" 512)
  (setq EP (ENTSEL "\n* Select Element to Break *")
        P1 (CADR EP)
        EN (CAR EP))
  (REDRAW EN 3)
  (setvar "OSMODE" OSM)
  (setq P2 (getpoint "\n* Show Point to Divide *"))
  (command "BREAK" P1 "F" P2 P2)
  (princ))
Sometines I get this error:
Invalid point, polygon segment is zero length.
; error: Function cancelled
« Last Edit: August 17, 2009, 03:35:58 PM by GDF »
Spike Wilbury
Re: Break Line at Point or Intersection
« Reply #1 on: August 17, 2009, 03:40:21 PM »
I still use this one on A2009....
(defun C:BRK  (/ osm pt ptlst ss num num1 count)
  (defun *error*  (msg)
    (if eco
      (setvar "cmdecho" eco))
    (if osm
      (setvar "osmode" osm))
    (setq *error* nil)
    (princ))
  (setq eco (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq osm (getvar "osmode"))
  (command "_.osnap" "_int")
  (setq pt (getpoint "\nSelect intersection to break objects: "))
  (setq ptlst (list (car pt) (cadr pt)))
  (setq ss (ssget "_C" ptlst ptlst))
  (setq num   (sslength ss)
num1  (sslength ss)
count 0)
  (if (= 1 num1)
    (progn (prompt "\nInvalid point"))
    (progn (repeat num
     (command "_.break" (ssname ss count) ptlst ptlst)
     (setq count (1+ count)))))
  (setq *error* nil)
  (princ))
GDF
« Reply #2 on: August 17, 2009, 03:43:29 PM »
Perfect, thank you. My old routine just went into the trash can.
Spike Wilbury
« Reply #3 on: August 17, 2009, 03:55:18 PM »
not an elegant code, but appears that have been done the job for many years.... :)
KewlToyZ
« Reply #4 on: August 17, 2009, 04:27:11 PM »
There have been quite few interesting routines posted in here for this:
My favorite by CAB:
http://www.theswamp.org/index.php?topic=10370.0
Another with specialized requests
http://www.theswamp.org/index.php?topic=25808.0
« Reply #5 on: August 17, 2009, 04:45:16 PM »
;;  Break at intersection, modified by CAB
;;  Not that a circle will not be broken!
(defun C:BRK (/ *error* osm pt ptlst ss num num1 count)
    (and msg (print msg))
    (and eco (setvar "cmdecho" eco))
    (and osm (setvar "osmode" osm))
  (command "._undo" "_begin")
  (setvar "osmode" 96)        ; int
  (if (and
    (if (< (setq num (sslength ss)) 2)
      (repeat num
        (command "_.break" (ssname ss (setq num (1- num))) ptlst ptlst))
  (command "._undo" "_end")
  (*error* nil)
GDF
« Reply #6 on: August 17, 2009, 04:51:53 PM »
Thanks Alan, I like the way this one works.
« Reply #7 on: August 17, 2009, 04:54:21 PM »
Thanks, just a little cleanup and some added error checking.  8-)
