Author Topic: F8 no longer works  (Read 1394 times)
whdjr
F8 no longer works
« on: November 18, 2005, 10:32:45 AM »
What drives the connection of the F8 key to Ortho.  I can't get my F8 key to work my ortho command.  If I right click on the ortho button it doesn't let me go into settings.
Any ideas?
Sdoman
Re: F8 no longer works
« Reply #1 on: November 18, 2005, 03:16:34 PM »
Hmm... I don't think there are any settings for Ortho other that "on" or "off".  Perhaps that explains why the right-click menu show "settings" grayed out.
If the F8 key doesn't toggle Ortho but the Ortho command works fine, then I would suspect the keyboard is broken.  You can also manipulate Ortho using Orthomode sys var.
Jakes GrandPa
« Reply #2 on: November 18, 2005, 11:40:45 PM »
Are you using any other software that captures the F8 keystroke before it gets to Acad? It would probably be something someone recently installed on your conmputer/network. We had some problems with the raster image manipulation software capturing certain keystrokes before Acad got them.
whdjr
« Reply #3 on: November 19, 2005, 07:33:57 AM »
It works this morning.  Guess it needed a reboot.
DeLoach's Computer Terms Dictionary
reboot = Another kick in the butt.    :-D
