Author Topic: is it smart / good to use vlax-get-property 'objectname to filter  (Read 2165 times)
nobody
  • .net stuff
I am trying to filter an entsel by checking if a vla object is a "AeccDbFeatureLine" using an "if" statement.  for example:
(if (= objname "AeccDbFeatureLine")(do something)(else quit command)....
Any thoughts about this?  I'd like to keep the entsel for it's single object selection behavior and can't find how to force a filter on it.
Thanks!
pBe
Re: is it smart / good to use vlax-get-property 'objectname to filter
« Reply #1 on: March 03, 2013, 07:25:50 AM »
Not sure:
(if(setq obj (ssget "_:S:E" '((0 . "AECC_FEATURE_LINE"))))
(do something)
nobody
  • .net stuff
« Reply #2 on: March 03, 2013, 08:53:24 AM »
Not sure:
(do something)
Thanks PBE... that was my alternate approach... trying to avoid the ssget function for this specific scenerio...really wish they built in filtering with entsel.
« Reply #3 on: March 03, 2013, 09:01:11 AM »
Here is a simple alternative:
;; Select if Object  -  Lee Mac
;; Continuously prompts the user for selection of an
;; entity matching the given entity type pattern.
;; Arguments:
;; msg  -  Selection prompt
;; typ  -  Entity type wildcard pattern, e.g. "*LINE"
;; Returns: ename of selected entity, else nil
(defun LM:SelectIfObject ( msg typ / ent )
    (while
        (progn (setvar 'errno 0) (setq ent (car (entsel msg)))
                (   (= 7 (getvar 'errno))
                    (princ "\nMissed, try again.")
                (   (= 'ename (type ent))
                    (if (not (wcmatch (cdr (assoc 0 (entget ent))) (strcase typ)))
                        (princ "\nInvalid object selected.")
    ent
For your case, call with:
(LM:SelectIfObject "\nSelect Feature Line: " "AECC_FEATURE_LINE")
nobody
  • .net stuff
« Reply #4 on: March 03, 2013, 09:12:09 AM »
Thanks!!  :-)
;; Arguments:
    (while
    ent
« Reply #5 on: March 03, 2013, 01:18:12 PM »
Here are some old routines to look at.
http://www.theswamp.org/index.php?topic=19808.0
nobody
  • .net stuff
« Reply #6 on: March 03, 2013, 01:50:45 PM »
Thank you CAB! I see several approaches in there. Really appreciate it.
