CAD Forums => CAD General => Topic started by: Krushert on January 26, 2010, 01:40:26 PM
Basically moving stuff from the Layer-NEW to Layer-EXISTING. IT is just that I have 174 layers with a lot of stuff on each layer to go thru and do the move and then times this for 4 more floors. I am using the Express Tools Layer-Merge command and it is working. But I am wondering how you guys do it.
+1 for Layer Merge
+1 for Layer Merge
Ditto!
I would use MAP witha range table and perform a single query operation similar to below:
If Object layer= then change to this other layer....
I would create small LISP.
Pseudo Code
Enter Prefix or select object for New Layer.
Using a filter allow user to select objects
If none selected use all objects in DWG that have that layer
Test for <prefix>-EXISTING layer, if not make it
Move selected objects to that layer.
This would require minimal user input. :-)
Ditto CAB but VBA
