Author Topic: delete block in all layout.  (Read 6833 times)
Andrea
« on: October 04, 2006, 11:47:53 PM »
Hi all...
I'm trying to find a routine who can delete a specific block name in ALL LAYOUT
without changing layout..
I know it's possible....but to much work here...
so if you can give me a hand...it will be appreciated..
thanks
Keep smile...
kpblc
Re: delete block in all layout.
« Reply #1 on: October 05, 2006, 12:35:40 AM »
(defun test (/ block_name)
  (if (and (setq block_name (getstring t "\nBlock Name : "))
   (tblobjname "block" block_name)
   ) ;_ end of and
    (foreach item
  (mapcar
    'vlax-ename->vla-object
    (vl-remove-if
      'listp
      (mapcar
'cadr
(ssnamex
  (ssget "_X"
(list '(0 . "INSERT")
       '(410 . "~model")
       (cons 2 block_name)
       ) ;_ end of list
) ;_ end of ssget
  ) ;_ end of ssnamex
) ;_ end of mapcar
      ) ;_ end of vl-remove-if
    ) ;_ end of mapcar
      (vla-erase item)
      ) ;_ end of foreach
    ) ;_ end of if
  ) ;_ end of defun
Sorry for my English.
CADmium
« Reply #2 on: October 05, 2006, 02:15:54 AM »
a function in ActivX :
(defun blockrefdelete(Blockname / Block)
  (vlax-for layout(vla-get-layouts(vla-get-activedocument(vlax-get-acad-object)))
    (vlax-for ITEM (vla-get-block Layout)
      (if(and(member(strcase(vla-get-objectname  ITEM))
                   '("ACDBBLOCKREFERENCE" "ACDBMINSERTBLOCK")
             (=(strcase(vla-get-name ITEM))(strcase BLOCKNAME))
        (vla-delete ITEM)
or try
(defun blockrefdelete(BLOCKNAME / LISTE)
  (if(and(setq BLOCK (tblobjname "block" BLOCKNAME))
         (setq LISTE(entget(cdr (assoc 330 (entget BLOCK)))))
         (setq LISTE(cdr(reverse(cdr(member(assoc 102 LISTE)LISTE)))))
    (mapcar '(lambda(X)
               (not(vl-catch-all-error-p
                     (vl-catch-all-apply
                       'vla-delete
                       (list X)
             (vl-remove-if-not '(lambda(Y) Y)
                (mapcar '(lambda(X) (vlax-ename->vla-object  X))
                        (mapcar '(lambda(X) (cdr X)) LISTE)
and you can call both functions
(blockrefdelete (cdr(assoc 2(entget(ssname (ssget "_:S" '((0 . "INSERT")))0)))))
« Last Edit: October 05, 2006, 03:48:16 AM by CADmium »
"Bei 99% aller Probleme ist die umfassende Beschreibung des Problems bereits mehr als die Hälfte der Lösung desselben."
Patrick_35
« Reply #3 on: October 05, 2006, 09:30:40 AM »
Hi
An another
(defun c:delb(/ bloc bls bl ent)
  (if (setq bloc (getstring T "\nBlock name : "))
    (if (tblsearch "block" bloc)
        (setq bls (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
        (vlax-for bl bls
          (vlax-for ent bl
            (if (eq (vla-get-objectname ent) "AcDbBlockReference")
              (if (eq (strcase (vla-get-name ent)) (strcase bloc))
                (vla-delete ent)
      (princ (strcat "\nBlock " bloc " don't exist"))
kpblc
« Reply #4 on: October 05, 2006, 09:43:46 AM »
Your code will erase block definition, not reference (i think). And anyway you're working with block collection (not insertions)
Patrick_35
« Reply #5 on: October 05, 2006, 10:08:43 AM »
There is an trick. Test it
« Reply #6 on: October 05, 2006, 10:18:02 AM »
This is an oldie I created. May not be what you want.
Deletes a list of block names and purges them.
<edit: removed code as it does not work as planed>
« Last Edit: October 05, 2006, 10:49:28 AM by CAB »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: October 05, 2006, 10:25:58 AM »
Today, my morning began from such program and coffee...
Your program deletes all blocks only in the last page
« Reply #8 on: October 05, 2006, 10:37:23 AM »
Thanks Evgeniy
Checking the code, you are correct.
Back then I was using one layout drawings & switched to xrefs & multi tabs
and left that code behind. I'll put it in the trash bin and use yours. :)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #9 on: October 05, 2006, 10:40:56 AM »
I have deleted the last post...
Has rechecked it is it does not work: (
« Reply #10 on: October 05, 2006, 11:20:05 AM »
kpblc & Evgeniy
If I may be so bold, I took your routines & modified for my subroutine like this.
(defun delblock_1 (bnames / ss)
  (if (setq ss
             (ssget
               "_X"
               (list
                 '(0 . "INSERT")
                 (cons 2
                       (substr
                         (apply
                           (function strcat)
                           (mapcar (function (lambda (x) (strcat "," x)))
                                   bnames
                         2
                       ) ;_  substr
               ) ;_ end of list
             ) ;_ end of ssget
    (foreach item
                  (mapcar
                    (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
                  ) ;_ end of mapcar
      (vla-erase item)
    ) ;_ end of foreach
) ;_ end of defun
(delblock_1 '("Aproved Title Block D" "Aproved Title Block"))
« Last Edit: October 05, 2006, 11:29:11 AM by CAB »
Andrea
« Reply #11 on: October 05, 2006, 05:23:27 PM »
Woo !   :roll:
thanks all for the quick response..
Keep smile...
whdjr
« Reply #12 on: October 10, 2006, 03:46:36 PM »
This is my favorite however I am partial.   :-)
Andrea
« Reply #13 on: October 11, 2006, 01:21:59 PM »
nice one wh... :wink:
Keep smile...
ELOQUINTET
« Reply #14 on: February 02, 2007, 04:23:35 PM »
I just happened to come across this post in a search and was wondering if anyone has a lisp that I could run in a batch script to get rid of a specified block from all layouts without picking it. It would also be splendid if it then purged the block out of the drawing. I know this is available just haven't had the time to do a full sweep of the forum today.
