Author Topic: Using EVAL & READ  (Read 1534 times)
Using EVAL & READ
« on: June 15, 2009, 01:47:14 PM »
I have been experimenting with a new approach to updating objects with Visual LISP, and was trying to formulate a different way to update various properties at once.
Something like:
(defun c:mtxt (/ tEnt tObj ss)
  (if (and (setq tEnt (car (entsel "\nSelect Source Text: ")))
           (wcmatch (cdadr (entget tEnt)) "ATT*,*TEXT")
           (setq tObj (vlax-ename->vla-object tEnt)))
    (while (setq ss (ssget '((0 . "*TEXT,ATT*"))))
      (foreach Obj (mapcar 'vlax-ename->vla-object
                     (vl-remove-if 'listp
                       (mapcar 'cadr (ssnamex ss))))
        (foreach fun '("Layer" "Color" "Height" "ObliqueAngle" "ScaleFactor" "StyleName")
          (eval ((read (strcat "vla-put-" fun)) Obj
                  ((read (strcat "vla-get-" fun)) tObj))))))
    (princ "\n<< Nothing Selected >>"))
  (princ))
The section I am struggling with is:
I keep receiving a "bad-function" error.
I am not experienced in using the "eval" and "read" functions, so help in this matter is much appreciated  :-)
Thanks for your time,
Lee
Re: Using EVAL & READ
« Reply #1 on: June 15, 2009, 02:05:43 PM »
No need to do all that.  Here is an example
ob2 = valid AX object
Command: (vla-get-layer ob2)
"temp"
Command: (setq lay "0")
"0"
Command: (setq prop "layer")
"layer"
Command: (vlax-put ob2 prop lay)
nil
"0"
« Reply #2 on: June 15, 2009, 02:07:44 PM »
Note that you will get an error as there is no 'ObliqueAngle' property in Mtext.
          ((eval (read (strcat "vla-put-" fun))) Obj
                  ((eval(read (strcat "vla-get-" fun))) tObj)))))
  (princ))
Also see (vlax-get-property object property) and (vlax-property-available-p obj prop [check-modify])
« Last Edit: June 15, 2009, 02:16:50 PM by CAB »
« Reply #3 on: June 15, 2009, 08:54:50 PM »
Thanks for the information guys, this is what I went with in the end:
        (foreach fun '(Layer Color Height ObliqueAngle ScaleFactor StyleName)
          (if (and (vlax-property-available-p tObj fun)
                   (vlax-property-available-p Obj fun t))
            (vlax-put-property Obj fun
              (vlax-get-property tObj fun))))))
  (princ))
Let me know if you see any room for further improvement - I'm always looking to improve.   8-)
Thanks,
Lee
