Author Topic: dgn to dwg en vice versa?  (Read 3326 times)
Amsterdammed
« on: September 21, 2005, 04:18:34 AM »
Hello folks,
From a poor collage of mine from a remote office here I got the question if there is a way to convert Microstation’s dgn format to dwg and vice versa. The costumer we have to deal with refuses to convert his dgn to dxf. Is there any peaceful solution?
Thanks in Advance
Bernd
Re: dgn to dwg en vice versa?
« Reply #1 on: September 21, 2005, 04:27:35 AM »
I know Map will read a dgn. If you want to see the results give me a dgn file and I'll convert it when I get to work this morning.
Amsterdammed
« Reply #2 on: September 21, 2005, 04:35:42 AM »
Mark,
Thanks for the offer, but I don't know how many drawings there are involved and how many times this must be done. So I guess I need a solution my colleagues can do them self. I would never bother somebody here at the swamp to do our company's work.
Thanks,
Bernd
PS what is MAP??
Amsterdammed
« Reply #3 on: September 21, 2005, 04:37:59 AM »
Mark,
I couldn’t help checking on your Profile since I was sure you are Tampa located. Isn’t that a bad time to be online? Shouldn’t you be in Bed??
« Reply #4 on: September 21, 2005, 04:52:02 AM »
Mark,
Thanks,
Bernd
PS what is MAP??
AutoCAD Map , sorry it's to early for a link  . . .  :-)
I wasn't planning on doing your companies work ( of course your work would be a different story ), I was just going to give you an idea of what the out come looked like.
« Reply #5 on: September 21, 2005, 04:53:24 AM »
Mark,
Never a bad time to be online. *grin*
But yes it is a bit early.
« Reply #6 on: September 21, 2005, 04:55:36 AM »
hehehehe
did the breeze in the trees wake you ?
« Reply #7 on: September 21, 2005, 06:47:42 AM »
hehehehe
Nah, I'm not a light sleeper. I've slept through I think . . . 3 hurricanes now.
