Author Topic: New Item in dictionary  (Read 6007 times)
andrew_nao
Re: New Item in dictionary
« Reply #15 on: July 29, 2013, 09:11:39 AM »
is there a way to count how many xrecords are in a document?
irneb
« Reply #16 on: July 29, 2013, 09:49:01 AM »
Probably, but it's going to be: Go through each dictionary (including all attached to the namedobjdict and each entity in the entire database), then use dictnext to find each XRecord and inside each sub-dictionary (or any other such container entity). So it can be an extremely inefficient idea.
