Author Topic: Intersection Point of Hatch  (Read 1642 times)
udaafri
  • Mosquito
« on: February 11, 2023, 05:26:34 AM »
Is it possible to get the Intersection Point of Hatch with Lisp?
Crank
Re: Intersection Point of Hatch
« Reply #1 on: February 11, 2023, 05:31:45 AM »
Make sure the variable OSNAPHATCH=1
udaafri
  • Mosquito
« Reply #2 on: February 11, 2023, 05:43:40 AM »
Thanks for your reply.
I plan to collect all intersection points of the hatch.
I can find the intersection point of the line or Pline using AutoLisp, but not for the hatch.
ribarm
  • Marko Ribar, architect
« Reply #3 on: February 11, 2023, 08:24:58 AM »
Temporarily explode hatch, find intersection points between each pair of lines and finally do undo - before explode...
It shouldn't be so hard - look for LeeMac's intersection sub functions...
M.R. on Youtube
BIGAL
  • 40 + years of using Autocad
« Reply #4 on: February 11, 2023, 06:59:44 PM »
There is HB.lsp hatch boundary which makes a boundary  pline of the hatch. Is this what you want ?
udaafri
  • Mosquito
« Reply #5 on: February 12, 2023, 10:54:03 PM »
Thanks for your info.
If the hatch exploded that's no problem. I have found Lisp code.
udaafri
  • Mosquito
« Reply #6 on: February 12, 2023, 11:02:12 PM »
Not this one.
I wanna get the intersection point from the hatch and create something like a circle or put the point from these points.
« Reply #7 on: February 13, 2023, 01:25:08 PM »
You could create a copy of the hatch, explode the copy, and iterate over the objects generated from the explode operation using entnext, detecting intersections between such objects.
udaafri
  • Mosquito
« Reply #8 on: February 14, 2023, 04:55:02 AM »
Thanks for your explanation Lee.
danAllen
« Reply #9 on: February 14, 2023, 12:15:37 PM »
For example of a lisp that iterates objects and finds intersections, see CAB's break lisp. This is the latest version I could find:
http://www.theswamp.org/index.php?topic=10370.msg594917#msg594917
udaafri
  • Mosquito
« Reply #10 on: February 15, 2023, 09:55:30 PM »
danAllen Thanks for your info.
