Hi.
We have a problem in our office with 2007. Frequently, the windows dialog boxes (the red box & white cross in the top right) fail to appear. When you have the xref box open you can’t attach anything. You can’t use the hatch command or any other that uses the normal windows boxes.
All the other autocad boxes appear fine, change properties etc (the ones with the white cross in the top left). It only seems to be the windows boxes that have issues.
The maximize viewport button vanishes at the same time.
Dunno if this is a windows problem or an Autocad problem to be honest, but every other program works fine. Quitting out of Autocad and reloading solves the problem but it’s a real pain in the @$$ when you have to quit and reload multiple drawings.
Any Ideas anyone?
