Code Red => .NET => Topic started by: sinc on February 15, 2008, 06:20:26 PM
Has anyone tried implementing pop-up help on .NET forms in Autocad?
I'm trying to get balloons to pop open when the user hovers the mouse over a control, but I'm not sure how to proceed. I can't get a HelpProvider to work, but from the description, it sounds like I don't even want that style of help, even if I could get it to work. From the description, it sounds like a HelpProvider expects the user to hit F1 to see any of the pop-up balloons, and that's not what I want. I'm trying to get balloons to popup automatically, just from a mouse hover.
You need to look at input point monitor. You can start on this post, and read for a couple of pages. (http://www.theswamp.org/index.php?topic=18121.msg241642#msg241642) As far as having a bubble pop up, I never got that to work, and I don't think Glenn posted a solution for that either.
Richard,
do you mean
HelpProvider
or ToolTips
I think sinc is after balloons on the form, not on Acad entities.
Something like ...
using WinForms = System.Windows.Forms;
using FormBalloonTest;
[assembly: AcRx.CommandClass(typeof(kdub.Testing.Commands.TestCommands))]
namespace kdub.Testing.Commands
/// <summary>
/// Summary description for TestCommands Class.
/// </summary>
public class TestCommands
public TestCommands()
// TODO: Add constructor logic here
[AcRx.CommandMethod("Cmd1")]
static public void test()
TestFormForBalloons testForm = new TestFormForBalloons();
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(testForm);
namespace FormBalloonTest
public partial class TestFormForBalloons : Form
public TestFormForBalloons()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
this.Close();
private void TestFormForBalloons_Load(object sender, EventArgs e)
ToolTip toolTip01 = new ToolTip();
toolTip01.AutoPopDelay = 4000;
toolTip01.InitialDelay = 1000;
toolTip01.ReshowDelay = 500;
// Force the ToolTip text to display.
toolTip01.ShowAlways = true;
// Set up the ToolTip text.
toolTip01.SetToolTip(this.button1, "Press Me, Press me .... ");
toolTip01.SetToolTip(this.textBox1, "Add something inane to the textBox");
and the piccy ;
.. and ;
toolTip01.IsBalloon = true;
toolTip01.UseAnimation = true;
The zipped Solution is attached, for anyone interested ..
Perfect! Thanks, Kerry. I got off on a wrong tangent trying to deal with that HelpProvider class, and didn't even see the ToolTip one.
I'm pretty sure that you can add the tooltip in the properties sheet in the form designer too, you could in VB/A from memory, may save some coding time :)
Yes, you can.
I thought so too Mick, but couldn't see it when I went looking .. ;-) .. but there may be several reasons for that ..
It's in the Common Controls.
ahhh .. must be added from the Toolbox first ... too obvious :-)
Well, not exactly obvious. Why is it in with the Common Controls? Since this component works in a very similar manner to the HelpProvider class, why isn't the ToolTip in the Component section with HelpProvider and the other components? It seems to me that this component is mis-categorized. If it had been in the Components section with the HelpProvider, I would have found it myself.
Although really I probably should have seen it anyway. After all, I've used a fair number of TextBoxes now, and the TextBox is right next to the ToolTip.
