Code Red => AutoLISP (Vanilla / Visual) => Topic started by: PM on October 19, 2022, 05:23:51 AM
Hi.I use this lisp to draw lines in specific layers. Some times i want this layers to contain polylines (close or open). So i want to add a option at the end of the code (before change layer to 0) ,and ask me "Do you want to convert to polyline? (Y/N)"
and some way using pedit command to join them (Not all the lines in the same layer, only the lines i draw with this command)
(command "_.pedit" "_M" "" "_Y" "_J" "" "")
(command "_layer" "_m" "Layer1" "_c" "15" "" "") );end if
(command "_line" "non" s1
"non" s2
; layer to 0
(mapcar '
setvar '
("clayer" "cecolor" "celtype" "celweight") (list "0" "BYLAYER" "BYLAYER" -1)) )
any options?
Why don't you draw polylines to start with? If in the end you want individual items simply explode it.
Jedna zamerka Ron,...
Pri samom izgovoru eksploud... Cinjenicno je nepotrebno iskazivati Nobelizam zarad fundamentalizma...
Thanks i fix it
(DEFUN C:test
(/ CONVERT S1 S2 SS
) (command "_layer" "_m" "Layer1" "_c" "15" "" "")
(COMMAND "_line" "non" S1
"non" S2
((getkword "\nConvert to polyline? [Yes/No] <N>: ")) ("No")
(= convert "Yes")
(command "_.pedit" "_M" ss
"" "_Y" "_J" "" "") (command "_.pedit" "_M" ss
"" "_J" "" "") )
(command "-linetype" "set" "Bylayer" "") )
Thanks i fix it
(DEFUN C:test
(/ CONVERT S1 S2 SS
"non" S2
(= convert "Yes")
"" "_J" "" "") )
Why are you doing this ?
Draw a line .. ask if it should be a polyline, repeat. Sorry I don't get your logic at all. :wink:
FWIW, This line will prevent the code from ever running: (if (tblsearch "layer" "Layer1")
