Author Topic: Look for combinations less than 100.  (Read 1380 times)
well20152016
« on: March 19, 2020, 10:31:37 PM »
The combination uses the method of exhaustion, which is slow.
Can we reduce the calculation amount by judging whether to clear the combination greater than 100 in advance.
(combinations-1 (list 40 30 30 33 80 60 55 10 20 10 80 90 50 50) 100)
(90 10)(90)
(80 20)(80 10 10)(80)
(60 40) (60 30 10)(60 20 10 10)(60 20 10)(60 33)(60 30)(60 20)(60 10)
(55 40)(55 33)(55 30)(55 30 10)(55 20 10) (55 20)(55 10) (55)
  1. (defun combinations (l)
  2.   (defun ncr (l r)
  3.     (cond
  4.       ((< r 2)
  5.         (mapcar
  6.           'list
  7.           l
  8.         )
  9.       )
  10.       (l (append
  11.            (mapcar
  12.              '(lambda (x)
  13.                 (cons (car l) x)
  14.               )
  15.              (ncr (cdr l) (1- r))
  16.            )
  17.            (ncr (cdr l) r)
  18.          )
  19.       )
  20.     )
  21.   )
  22.   (defun ncr< (l r)
  23.     (if (< 0 r)
  24.       (append
  25.         (ncr l r)
  26.         (ncr< l (1- r))
  27.       )
  28.     )
  29.   )
  30.   (ncr< l (length l))
  31. )
EDIT (John): Added code tags.
« Last Edit: March 20, 2020, 08:45:52 AM by John Kaul (Se7en) »
well20152016
Re: Look for combinations less than 100.
« Reply #1 on: March 20, 2020, 12:48:31 AM »
The speed is too slow and there are too many repetitions. Is there any way to optimize it? Get > cap 70%
  1. (defun combinations-1 (l cap / i  k)
  2.     (setq i (car l)
  3.           l (cdr l)
  4.           k (mapcar '(lambda (x) (cons i x)) (append (mapcar 'list l) k1))
  5.           k1 (vl-remove-if'(lambda (y)(>  (apply '+ y) cap)) k)
  6.     )
  7.   l2)
  8. )
« Last Edit: March 21, 2020, 07:45:38 PM by well20152016 »
« Reply #2 on: March 20, 2020, 09:23:17 AM »
well20152016
« Reply #3 on: March 20, 2020, 07:49:43 PM »
Lee Mac, thank you for your code! I wonder if I can optimize the algorithm to reduce the combination of less than 100 in (defun NCR < (L R)).
