Okay, here is the latest pic.
The linetype will not go to the edges of the container, so I cannot use my 'Water' hatch inside it.
Which number do I mess with?
I'll be honest with you, that's one thing I've had trouble with as well. Text linetypes will never be truly awesome, because unless it can complete the next 'repetition' in it's entirety, it just leaves it off and ends it with either a dash, or a space, depending on how you started it ( I think )
I'm sorry, I don't know how much help I can be.
I changed the code to this:
*WATER,Water Linetype UUUUUUUUUUU
A,0,["(",STANDARD,S=.5,R=90.0,X=.27,Y=-.1],-0.75
Which helped eliminate SOME of the offset, but you can never get it to completely fill the length of the line. If there's not enough room to fit a WHOLE parenthesis, it won't put one at all... it's unfortunate, but one of those quirks :\
Kind of like if you have a CENTER linetype... and the line is too short, it won't show ANY dashes, making it look continuous... same reason, here.
What I've done before is play with the line length and just find the best fit. Sometimes if you make it a LITTLE longer than the box, in this case, it might "appear" better. Gotta just find the best case.
Maybe better would be a dynamic block... got those in LT?
