Author Topic: Constrain WB-67 Interstate Semitrailer to turning path  (Read 10160 times)
Dommy2Hotty
« on: July 14, 2008, 04:01:35 PM »
I'm trying to make a dynamic block of a WB-67 Interstate Semitrailer.  What I have so far is the correct sizing for the truck & trailer and what I believe to be the correct turning radii.  I also have independantly rotating cab & trailer.  Is there a way to move the cab to any point of of the turn and have the trailer follow and rotate along trailer turning radius?
jnieman
Re: Constrain WB-67 Interstate Semitrailer to turning path
« Reply #1 on: July 14, 2008, 05:25:15 PM »
Not with just a dynamic block, no.
I don't even know how you'd do it programmatically without just redrawing the whole block after the user inputs the point for the cab, but I'm also not a programmer.
You'd have to be able to associate a point or object to always be coincident with another object (centerline) and I don't think that could happen.
Dommy2Hotty
« Reply #2 on: July 15, 2008, 10:28:42 AM »
Well, I did send my contact info to Transoft for the AutoTurn product...used it yesterday, liked what I saw...
http://www.transoftsolutions.com/ProductTmpl.aspx?product=AT
architecture68-raff
  • Strange things are afoot at the Circle-K.
« Reply #3 on: July 15, 2008, 10:36:10 AM »
There is a free open source program called turn.lsp that you may want to check out before you spend any money.
http://www.hawsedc.com/gnu/turn.php
I've never used it personally, but I've heard of others using it as an alternative to Autoturn.
Chicago, Illinois
ADT 2005, Revit Architecture 2009, Sketchup 7
jnieman
« Reply #4 on: July 15, 2008, 11:15:06 AM »
heh
we print out our site plan to scale, and print out the little drawing of the turning radius that goes with DOT guidelines and just sort of over-lay it and see if it works :P
It's kind of like playing with paper dolls, but hey, it works.
Dommy2Hotty
« Reply #5 on: July 15, 2008, 12:47:47 PM »
heh
Would I be able to get a copy of that template?
jnieman
« Reply #6 on: July 15, 2008, 12:59:25 PM »
heh
Boss is at lunch for now, I'll ask if he has those transparencies.  He got them from the civil firm we usually sub our site work to.  I'll post back later if we can dig 'em up.
Dommy2Hotty
« Reply #7 on: July 15, 2008, 06:27:21 PM »
What are those??? I'm only 27...
jnieman
« Reply #8 on: July 15, 2008, 06:49:41 PM »
I'm 24, man!  I don't know what you call them, but I'm talking about the 8 1/2" x 11" sheets of plastic that are see-through, and used mainly for overhead projectors, like teachers used before Powerpoint.
We print the turning radii stuff on the transperancy, then overlay it over our site plan, plotted to match the transparency scale... then we just kind of maneuver it around and make sure it fits decent enough.  Wasn't able to find them though... may have given them back to the other company already.
Did find the same image online, though.
« Last Edit: July 15, 2008, 06:56:03 PM by jnieman »
jonesy
  • SuperMod
« Reply #9 on: July 16, 2008, 02:54:17 AM »
If thats anything like our "Autotrack" its a great product... good fun too, driving a big truck, and trying to reverse it.
Dommy2Hotty
« Reply #10 on: July 16, 2008, 11:01:08 AM »
I was just kidding!  But thank you for the image, that will help.
jnieman
« Reply #11 on: July 16, 2008, 11:23:26 AM »
We just don't do parking lots often enough to warrant buying a product... heck the company we give our decent sized site work to is a small business (2 engineers, one designer, and a survey crew of 2) and they use the transparency method because they try to cut costs and "if it ain't broke, don't fix it"
