xData can be filtered using the AppID in the ssget filter list:
(ssget "_X" '((-3 ("TopoWAR"))))
However, you cannot filter lower than the AppID from an ssget filter list, if you wanted to filter lower, you would need to iterate over the set and operate on only those entities matching a certain criteria.
However, as I'm sure you can see, even filtering the initial set by an xData AppID significantly reduces the number of objects to be checked so you are left with few, if none, that are not required.
