Author Topic: Vanilla in contention with Visual  (Read 10216 times)
Chuck Gabriel
« on: February 24, 2006, 09:58:13 AM »
I know this has been discussed before, if not here then on the Autodesk forums, but I'd like to hear about it from some of the folks here.
Right around the time I started using some of the ActiveX stuff provided by Visual LISP, I started having problems with previously solid code, that used the traditional "vanilla" AutoLISP techniques, failing intermittently (i.e. (setvar "clayer" "somelayer") would fail from time to time).The conventional wisdom, at the time, was to convert any problematic code to use ActiveX equivalents for things like entmod and entmake, and that is precisely what I have done.  However, I still occasionally encounter problems related to this phenomenon.
Is wholesale conversion to ActiveX still considered the best way to deal with the issue?  Has anybody ever discovered an actual root cause for the problem?  Can any of you advise me on a better way to handle this?
Re: Vanilla in contention with Visual
« Reply #1 on: February 24, 2006, 10:56:57 AM »
Okay this is going to sound weird but... I remember when Stig just roasted me on some code once. I spent hours-days on a proced to "draw a line" and I asked Stig how it was looking/shaping up and he said to me: there is nothing wrong with the use of command if you are careful and set up the environment. I mean we've all seen the type of code:
(defun foo ()
  (defun crap?! (s)
    (setq *error* olderr
          olderr  nil)
    (setvar "cmdecho" 1)
    (princ) )
  (setq olderr *error* *error* crap?!)
  (setvar "cmdecho" 0)
  (setq a (getpoint "\nenter a point dummy: "))
  (setq b (getpoint a "\nenter another point airhead: "))
  (command "_line" a b "")
  (quit)
But there is actual validity in that type of code. When done properly you don't really need a hundred lines of VL code with the PROPER use of `command'. (But therein lies the problem with most new users they don't know how to properly set up the situation and they often get/produce crapy code that looks even worse because they used command.)
If you were to take a look at my "general util" file that gets loaded on start up (the one full of a bunch of lisps I use allt he time) you would think that I didnt know the first thing about Autolisp or Visual lisp. ...I mean take a look at this stuff.
;; move command maped to 'vv'.
(defun c:vv () (princ "MOVE") (command "_.move") (princ) )
;;; set the current layer to the one selected.
(defun c:as ( / lay)
 (while (not (setq lay
   (cdr (assoc 8 (entget (car (entsel))))))))
  (command "layer" "s" lay "")
  (princ) )
;Copy & Rotate in one tool
(defun c:cr (/ p1 objects)
  (prompt "Select Objects: ")
  (setq objects (ssget))
  (setq p1 (getpoint "Select base point: "))
  (command "copy" objects "" p1 p1)
  (command "move" objects "" p1 pause)
  (command "rotate" objects "" (getvar "lastpoint") pause)
My most precious file is loaded with this type of code. (I should really update that thing.)
So what im trying to say is unless you writing for development purposes there "REALLY" isnt a need for a full on ActiveX assult most times.
Chuck Gabriel
« Reply #2 on: February 24, 2006, 11:22:43 AM »
That's all well and good, and I've recently begun to relax regarding that particular issue, but command isn't one of the functions that fails intermittently.  It's primarily stuff like setvar, entmod, entmake, and etc.
Here is a prime example.  I use the following functions to store system variable states at the beginning of a function and restore them at the end:
(defun CollectVars (varlst / varnam)
  (foreach varnam varlst
    (setq varlst (subst (cons varnam (getvar varnam)) varnam varlst))
(defun RestoreVars (varlst / varnam)
      ((= (strcase (car varnam)) "CLAYER")
       (vla-put-activelayer
*thisdrawing*
(vla-item (vla-get-layers *thisdrawing*) (cdr varnam))
      (T (setvar (car varnam) (cdr varnam)))
See that bit of ActiveX code in RestoreVars?  I had to do that because the function would periodically kak when trying to restore the clayer system variable to its previous value.
That's just a sample of the types of failures that have occurred.
« Reply #3 on: February 24, 2006, 11:36:42 AM »
Thats because:
clayer will NOT restore this way. (setvar)
viewres will not resore this way. (setvar)
(Im sure there are others, but these are the two that ive found from 2000 on.)
Entmod and Entmake are two that bring up another issue.
But the point i was trying to make is that command can be used safely to offer you another alternitive to VL methods (Or etc.) for doing some of the "broken" methods.
Chuck Gabriel
« Reply #4 on: February 24, 2006, 11:52:20 AM »
Thats because:
Wanna bet?
(setvar "clayer" "0") at the command line works just fine for me (most of the time).
By the way, thanks for jumping in.  I do appreciate your advice even if it doesn't seem that way. :D
« Reply #5 on: February 24, 2006, 12:36:31 PM »
yeah!
Command: (setvar "clayer" "0")
; error: AutoCAD variable setting rejected: "clayer" "0"
No, i enjoy discussions. (Specially with somone of your calibur [sp])
...hold on, ill be right back.
« Reply #6 on: February 24, 2006, 12:41:39 PM »
Okay im back...
Ah HA! I found some backing! This is a var resore function from AcadX and 'it' thinks the same way I do. (Okay thats enough being cocky from me.) This must be where I got the clayer and viewres thing. Cause I used to read acadx alot when I was learning.
(defun vlxx-VarRestore ( / $orr #err)
  (defun #err (s)
    (princ (strcat "\nError: " s))
    (setq G$VARS nil)
    (setq *error* $orr)
  (setq $orr *error* *error* #err)
    ( (and G$VARS (listp G$VARS))
     (foreach n G$VARS
                ( (= (strcase (car n)) "CLAYER")
                 (command "_.layer" "_s" (cadr n) "")
                ( (= (strcase (car n)) "VIEWRES")
                 (command "_.viewres" "_Y" (cadr n) "")
                ( T (setvar (car n) (cadr n)) )
     (setq G$VARS nil)
  (setq *error* $orr $orr nil)
« Reply #7 on: February 24, 2006, 12:48:38 PM »
yeah!
If I'm not mistaken John setvar will only chuck a wobbly on clayer if the layer doesn't exist or is frozen, otherwise it works.
« Reply #8 on: February 24, 2006, 01:09:50 PM »
So then why does it not work on lay zero?
« Reply #9 on: February 24, 2006, 01:11:13 PM »
Worked here with layer 0.
Command: (SETVAR "CLAYER" "0")
"0"
Chuck Gabriel
« Reply #10 on: February 24, 2006, 01:12:03 PM »
It does (for me).  Maybe the problem that I experience intermittently is more pronounced on your machine.  Did you try it several times in succession?
« Reply #11 on: February 24, 2006, 01:12:43 PM »
...holly cow!?! It worked:
Command: (setvar "clayer" "M-HVAC")
"M-HVAC"
*blink*
So in otherwords, if we check to see if the layer is locked we can use setvar.
*Se7en runs off to do some testing*
« Reply #12 on: February 24, 2006, 01:14:08 PM »
yeah i did.
Command: (setvar "clayer" '0)
; error: AutoCAD variable setting rejected: "clayer" 0
Command: (setvar "clayer" 0)
Command: (setvar "clayer" 0)*Cancel*
Command: (set 'zero 0)
0
Command: (setvar "clayer" zero)
Command: (set 'zero '0)
0
Command: (setvar 'clayer zero)
; error: AutoCAD variable setting rejected: CLAYER 0
Command:
*hummmmm!*
Chuck Gabriel
« Reply #13 on: February 24, 2006, 01:17:09 PM »
You broke it!
« Reply #14 on: February 24, 2006, 01:37:25 PM »
FWIW, I have always used the (setvar "clayer" "whatever"). That is until I started using the ActiveX methods of StartUndoMark/EndUndoMark. When these are used, I then make sure to get & set all SysVars via activex as well.
    (setq varlst (subst (cons varnam (vlax-invoke
       *thisdrawing*
       'getvariable
       varnam))
      varnam varlst))
    (vlax-invoke
      *thisdrawing*
      'setvariable
      (car varnam)
      (cdr varnam)
