Author Topic: How to debug? (problems with debugging)  (Read 2851 times)
teslaxx
« on: January 14, 2011, 03:35:55 AM »
When I start the Visual Studio in debug mode, I can't load my dll in Autocad enviroment. When I enter the command name in the command line, I receive "Unknown command "MyCommand"."
When I load the dll, without being in the debug mode, all goes smoothly. :)
I'm using VS 2008 and Autocad 2011.
Any tips?
Re: How to debug? (problems with debugging)
« Reply #1 on: January 14, 2011, 04:16:08 AM »
What do you mean by
Does it error ?
How are you loading the debug DLL ??
teslaxx
« Reply #2 on: January 14, 2011, 04:35:41 AM »
With netload command. I don't receive any error when I select the dll file.
« Reply #3 on: January 14, 2011, 04:37:02 AM »
How long is a piece of string ??
teslaxx
« Reply #4 on: January 14, 2011, 04:43:35 AM »
How long the name of the command is? "km2"
teslaxx
« Reply #5 on: January 14, 2011, 06:15:16 AM »
Fix it!
Link: http://forums.autodesk.com/t5/NET/Debug-problems/m-p/2640779
In your project references, make sure the CopyLocal property for acmdg.dll and acdbmgd.dll, and any other Autodesk-supplied assemblies, are all set to false.
I don't know how this thing happen, because this is the first thing I do, after I add the Autocad references.
mohnston
  • CAD Programmer
« Reply #6 on: January 14, 2011, 12:57:01 PM »
CAD Programming Solutions
