The MENULOAD at startup does not work and shows ERROR. Already run the TESTE command Works.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.EditorInput
Imports System
Namespace APPTESTENAME
Public Class Initialization
Implements IExtensionApplication
Public Sub Initialize() Implements IExtensionApplication.Initialize
MsgBox("START OK")
Try
Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim LINHA As String
LINHA = "(IF (NOT (MENUGROUP ""TOPOCAD2000"")) (PROGN(COMMAND ""_MENULOAD"" ""TOPOCAD2000"")(MENUCMD ""P15=+TOPOCAD2000.POP1""))(ALERT ""\nMENU ALREADY LOADED"") ) "
acDoc.SendStringToExecute(LINHA, True, False, False)
Catch
MsgBox("ERRO")
End Try
Public Sub Terminate() Implements IExtensionApplication.Terminate
End Class
Public Class COMANDOS
<CommandMethod("TESTE")> _
Public Sub Teste()
Dim LINHA As String
End Class
End Namespace
