Author Topic: Copy block  (Read 1849 times)
latour_g
Copy block
« on: January 07, 2014, 03:20:07 PM »
This function is to copy block.  First, you select the blocks that you want to replace and after you select the block to be copied. The only thing that don't work like I want is the position of the attributes, I can't set the new position (see at the end of the code).  If anyone can help me on that ... I would appreciate :-)
        private void btnCopyBlk_Click(object sender, EventArgs e)
            Document doc = AcadApp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            TypedValue[] values = new TypedValue[] { new TypedValue((int)DxfCode.Start, "INSERT") };
            SelectionFilter filter = new SelectionFilter(values);
            PromptSelectionOptions SelOpts = new PromptSelectionOptions();
            SelOpts.AllowDuplicates = false;
            SelOpts.MessageForAdding = "Select objects: ";
            SelOpts.MessageForRemoval = "Select objects to remove";
            Utils.SetFocusToDwgView();
            PromptSelectionResult res = ed.GetSelection(SelOpts, filter);
            if (res.Status != PromptStatus.OK) return;
            PromptEntityOptions peo = new PromptEntityOptions("Select block");
            peo.SetRejectMessage("No block selected");
            peo.AllowNone = false;
            peo.AddAllowedClass(typeof(BlockReference), false);
            PromptEntityResult per = ed.GetEntity(peo);
            // abandon si la sélection n'a pas été faite
            if (per.Status != PromptStatus.OK) return;
            DocumentLock loc = doc.LockDocument();
            using (Transaction tr = doc.Database.TransactionManager.StartTransaction())
                BlockTable bt = (BlockTable)tr.GetObject(doc.Database.BlockTableId, OpenMode.ForRead);
                // detail du bloc de remplacement
                BlockReference blkR = (BlockReference)tr.GetObject(per.ObjectId, OpenMode.ForRead);
                BlockTableRecord btNr = (BlockTableRecord)tr.GetObject(bt[blkR.Name], OpenMode.ForRead);
                SelectionSet ss = res.Value;
                ObjectId[] idArray = ss.GetObjectIds();
                foreach (ObjectId id in idArray)
                    SortedList<string, string> attLst = new SortedList<string, string>();
                    SortedList<string, AttributeReference> attAR = new SortedList<string, AttributeReference>();
                    BlockReference blk = (BlockReference)tr.GetObject(id, OpenMode.ForWrite);
                    // il y a des attributs dans le block à remplacer
                    // les effacer
                    foreach (ObjectId attId in blk.AttributeCollection)
                        if (attId.IsErased) continue;
                        AttributeReference att = (AttributeReference)tr.GetObject(attId, OpenMode.ForWrite);
                        att.Erase(true);
                    // il y a des attributs dans le block de remplacement
                    // lire les valeurs associées aux tag
                    foreach (ObjectId attId in blkR.AttributeCollection)
                            AttributeReference att = (AttributeReference)tr.GetObject(attId, OpenMode.ForRead);
                            if (!attLst.ContainsKey(att.Tag))
                                attLst.Add(att.Tag, att.TextString);
                                attAR.Add(att.Tag, att);
                    blk.BlockTableRecord = btNr.ObjectId;
                    blk.Layer = blkR.Layer;
                    // il y a des attributs dans le bloc de remplacement
                    if (btNr.HasAttributeDefinitions)
                        // ajout des attributs a la reference du block
                        IEnumerator Ie = btNr.GetEnumerator();
                        while (Ie.MoveNext())
                            try
                                DBObject obj = tr.GetObject((ObjectId)Ie.Current, OpenMode.ForRead, false);
                                if (obj.GetType() == typeof(AttributeDefinition))
                                    AttributeDefinition attDef = (AttributeDefinition)obj;
                                    //Create a new attribute reference
                                    AttributeReference attRef = new AttributeReference();
                                    AttributeReference attRefCopie = new AttributeReference();
                                    if (attLst.ContainsKey(attDef.Tag)) attRef.TextString = attLst[attDef.Tag];
                                    if (attLst.ContainsKey(attDef.Tag)) attRefCopie = attAR[attDef.Tag];
                                    attRef.SetDatabaseDefaults();
                                    attRef.SetAttributeFromBlock(attDef, blk.BlockTransform);
                                    attRef.Layer = attRefCopie.Layer;
                                    attRef.TextString = attRefCopie.TextString;
                                    attRef.Rotation = attRefCopie.Rotation+blk.Rotation;
                                    attRef.Color = attRefCopie.Color;
                                    attRef.TextStyleId = attRefCopie.TextStyleId;
                                    attRef.Justify = attRefCopie.Justify;
                                    // Not working
                                    attRef.Position = attDef.Position.TransformBy(blk.BlockTransform);
                                    //Add the attribute reference to the block ref
                                    blk.AttributeCollection.AppendAttribute(attRef);
                                    tr.AddNewlyCreatedDBObject(attRef, true);
                            catch (System.Exception ex) { MessageBox.Show(ex.ToString()); }
                tr.Commit();
            loc.Dispose();
            Utils.PostCommandPrompt();
« Last Edit: January 08, 2014, 09:00:07 AM by latour_g »
fixo
Re: Copy block
« Reply #1 on: January 07, 2014, 04:24:34 PM »
On the quick glance
Set attref.position=...
before of
 attref.Justify=...
then add this line:
attref.AdjustAlignment(db);
latour_g
Re: Copy block
« Reply #2 on: January 07, 2014, 05:06:48 PM »
Still not working  :|
attRef.AdjustAlignment(db);
