Author Topic: Freezing Xref Layers  (Read 10159 times)
t-bear
Re: Freezing Xref Layers
« Reply #30 on: October 20, 2006, 08:45:59 AM »
I know I'm waaay behind on all this and I apologize, but I've been using this code for some time now. It will freeze layers within xrefs removing the need to bind....saves dwg size.....  Have a look.
(defun c:vplfrz   ()
  (setvar "TileMode" 0) ;  Force PaperSpace
  (setq vpFlag (getvar "cvport"))
  (if (= vpFlag 1)
      (setq sel-vpt 1)
      (setq sel-vport (car (entsel "\nSelect view port: ")))
      (if (= sel-vport nil)
     (alert "You must select a viewport\nTry again!")
     (c:vplfrz)
     (setq entvport (entget sel-vport))
     (if (= (cdr (assoc 0 entvport)) "VIEWPORT")
       (frz-vplayer)
         (c:vplfrz)
    ); else Viewport is already selected
    (frz-vplayer)
  ) ;endif (= vpFlag 1)
(defun frz-vplayer ()
  (setq   e2    (entget sel-vport)
   viewport (cdr (assoc 69 e2))
  (command "mspace")
  (setvar "cvport" viewport)
  (setq loop "")
  (while loop
    (setq
      pik (nentsel "\nSelect an item on XREF to Freeze: ESC to Exit:")
      ((/= pik nil)
       (setq lay (assoc 8 (entget (car pik))))
       (setq str (cdr lay))
       (command "vplayer" "f" str "All" "") ; Freeze in ALL viewports
      ((= pik nil)
       (alert "Nothing Selected!\nTry Again!")
       (frz-vplayer)
  ) ; End while
  (command "pspace")
(prompt "\nType VPLFRZ to run")
(prin1)
I wish I could give credit to the author, but I don't remember where I got it....didn't write it down....my bad.
This just in!  CAB found my reference to this routine from waaaay back.
From the "gurus" at the CADalog forums, Keith, Trev, Hendie & Paul
;Thanks for this routine...3/7/03
....and thanks Alan!  Going to add this to the routine now..................
« Last Edit: October 20, 2006, 09:22:33 AM by t-bear »
