Allright boys and girls apperntly all i need was a cold morning a hot cup of coffee and fresh approach.
So this morning I created a new layer, made the new layer current and xrefed in the first section, then used the bind-bind command, after binding I exploded it. Well I wanted to check to see if the layer were freezable at this point so, I created a new drawing xrefed in the new file and to my amazement i was able to freeze layers. WOW!!! So to go on, I followed the same process step by step. and again to my amazement it still would freeze the layers....HOLY SHAT!!!
TO make a long story short I found a solution to my problem and its seems to be working....so I would like to thank all of you and have a wonderful rest of the day....as you can probably tell I am much ahppier this morning....
Oh yeah and most importantly----!!!! GO CARDS !!!
