Author Topic: Freezing Xref Layers  (Read 10161 times)
TomREd
« on: October 11, 2006, 04:22:06 PM »
Ok, so I hae this huge school project and the Arch. has determined that there will be a base bid, an alternate #1, alternate #2.
Now this is fine well and good but the arch has set his up is mad. Xrefs inside of xrefs....this just makes me angry to start with... so after seperating everything, coloring as i would like them to be...i mad one new drawing and xrefed all the pieces together, and I had hoped that i could bind them all together with a bind-bind so that i would be left with very clearly differnt layer sets. as each of these drawings were sharing layer descriptions (ie. a-wall) this was a layer in each set the exist. biulding, the new section of building and the alternate sections. Now I hope you can see why i wanted to bind them so I had Ex.-a-wall, new-a-wall, and alt1-a-wall. well afer binding and all i thought i was in the home strect of setting up the hundred or so drawings that i need to create. well in creating the first sheet, I went in to try to freeze layers to make my floor plan, the dam things wont freeze and it keeps spitting out a message in the command line like :No matching layer names found. Damn well i though i left those bound xref as blocks in what i had hoped to be my xrefs. well i went and bursted the bound xrefs. to no avail. still same error. any suggestions...sorry so long winded just wanted to give as much info as possible!
Re: Freezing Xref Layers
« Reply #1 on: October 11, 2006, 04:41:58 PM »
Are all the drawings that comprise the project too big to zip up and post (or the info too proprietary)?
TomREd
« Reply #2 on: October 11, 2006, 04:49:06 PM »
I am kind of leary of posting drawings, but I would guess that it has nothing to do with the drwaings themselves. Its the matter of what happens when you bind these files together to create a new drawing and then after all that is done, I cannot freeze layers unless I select it from the layer manager.
TomREd
« Reply #3 on: October 11, 2006, 04:53:42 PM »
try yourself create three differnt drawings all with the same layer inside. for example:
new
old
future
inside each of these drawings create a layer wall
then xref each of the drawings together into one drawing, with the intent to bind-bind them together so that you end up with
new-wall
old-wall
future-wall
then use that as your new xref and xref into a new drawing. then try to change layers in the viewport.
they damn things wont respond, keep getting an error to the effect of: No matching layer names found
this is a basic explination of what im trying to do...hope this is more clear!
pmvliet
« Reply #4 on: October 11, 2006, 05:01:29 PM »
I understand your pain and what you are going through. The Architect has made it worse by doing all his nested xref's and such. I'm not exactly clear on if you just have one reference file now or if you have multiple xref's or blocks withing this one reference file. The basic jist of what I'm trying to say is that the layer names are not found due to that fact that something is being represented by a layer for which it doesn't belong to. Thats confusing.
It's like a block which has it's linework created on layer 0. When inserted it takes upon the properties of the layer it is inserted on. If the block is created with linework on layers 1, 2, & 3 and inserted on layer 4.
Things will get messed up. If you use the pick-freeze whcih you are trying to do, it will infact freeze layer 4, but layers 1,2 & 3 will still be visible. Even if you picked the entity that was created on layer 1.
If you confirm that this is true, then what you need to do (re-reading your post). You left the different xref's as blocks and then you exploded them. When you did this, what layer was current? and do you still have blocks beneath these blocks?
I just read you latest post and will try that.
Pieter
« Reply #5 on: October 11, 2006, 05:16:02 PM »
Sorry but I don't understand your problem.
What exactly are you trying to do with the layer & what is the exact name of the layer.
To freeze a xref layer use the layer manager, see below.
pmvliet
« Reply #6 on: October 11, 2006, 05:17:15 PM »
Do I bind this file? If you bind, the 3 different files becomes blocks.
Did you Bind or Insert?
If you Bind, you get layer names with:
old$0$wall
new$0$wall
future0$wall
If you insert, you get a  layer name of:
wall
with the properties of the layer that was in the first reference file attached/inserted.
all the items from the 3 different files go onto the same layer.
inserting also put's it into a block which is consistent of the file name.
TomREd
« Reply #7 on: October 11, 2006, 05:21:55 PM »
the whole reason i used the bind-bind command and not the bind-insert, was so that i would get a tag in front of the layer i.e. my example
old-wall
new-wall
future-wall
I can freeze from the layer pulldown or the layer manager, but my express tool layfrz wont select anything inside the viewport or in model space. This is what most people in my ofice use to freeze and the reason for my concern. I have no problem selecting the layers i want on and off from the menu but I dont want to have to hear it from thirty people in my office.
« Reply #8 on: October 11, 2006, 05:26:26 PM »
See if this works for you.
(defun c:LayFrez (/ ActDoc LayCol Sel EntData LayList BlkCol)
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(vla-EndUndoMark ActDoc)
(vla-StartUndoMark ActDoc)
(setq LayCol (vla-get-Layers ActDoc))
(setq BlkCol (vla-get-Blocks ActDoc))
(setvar "errno" 0)
(while (not (equal (getvar "errno") 52))
  (or
   (initget "Undo")
   (setq Sel (nentsel "\n Select object on layer to be frozen [Undo]: "))
  (if (= Sel "Undo")
   (if (car LayList)
     (vla-put-Freeze (car LayList) :vlax-false)
     (prompt (strcat "\n Layer \"" (vla-get-Name (car LayList)) "\" has been Unfroze."))
     (setq LayList (cdr LayList))
     (vla-Regen ActDoc acActiveViewport)
    (prompt "\n Nothing to undo.")
     (or
      (equal (length Sel) 2)
      (and
       (equal (length (last Sel)) 1)
       (= (vla-get-IsXref (vla-Item BlkCol (value 2 (entget (car (last Sel)))))) :vlax-true)
     (setq EntData (entget (car Sel)))
     (setq EntData (entget (car (last Sel))))
    (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-Freeze (list (setq LayObj (vla-Item LayCol (value 8 EntData))) :vlax-true)))
     (prompt (strcat "\n Could not freeze \"" (value 8 EntData) "\" layer."))
      (prompt (strcat "\n Layer \"" (value 8 EntData) "\" has been frozen."))
      (setq LayList (cons LayObj LayList))
TomREd
« Reply #9 on: October 11, 2006, 05:26:53 PM »
After using the bind command yes it creates blocks which were previously xrefs. I was on the 0 layer and used the burst command as to retain the layer settings from each of these drawings. Also I tried it with a full explode, neither made a difference.
And to add on, after attaching the newly created xref from the (previous 3) into a new drawing and the viewporting it to see if i could freeze layers and what not, i thought maybe i had an error or something and tried to detach the xref in ?, It tells me that its missing the xref and cannot detach...WTF!!!
The more I think about this the more I want to break something!
TomREd
« Reply #10 on: October 11, 2006, 05:34:29 PM »
Tim your lisp didn't do anything but give me a linetype error.
« Reply #11 on: October 11, 2006, 05:38:08 PM »
It looks like it might not work the way you want it to anyway, but what did the command line say? can you copy/paste it here?
I didn't want it to pick nested layers in blocks, I wanted the block to freeze, but that is an easy fix, and I can tell you have to fix that one.  I want to know what the other error is that you are getting.
Real quick.  The part you would want to change is this
     (or
      (and
to just
This way it will pick the most nested object.
Krushert
  • FREE BEER Tomorrow!!
« Reply #12 on: October 11, 2006, 05:47:23 PM »
old-wall
new-wall
future-wall
If you are trying to get this
old-wall
new-wall
future-wall
A different way to attack this.
I use a lisp that prefixes a string in front of the all layer names found in a drawing.  then I take that drawing and insert into my working drawing and explode.  This will save you hassle of binding the xref.
let me go find that lisp...BRB
« Last Edit: October 11, 2006, 05:49:02 PM by Krushert »
Kate M
« Reply #13 on: October 11, 2006, 05:50:40 PM »
Tom, what are your LAYFRZ options set to? Entity/Block/No nesting? Not sure if it'll help, but it may be worth a try.
Krushert
« Reply #14 on: October 11, 2006, 05:56:59 PM »
OPTIONS! OPTIONS! We have options?
Say it not true. Where?
