Code Red => AutoLISP (Vanilla / Visual) => Topic started by: Vikram on November 12, 2019, 01:56:42 AM
I want these commands to be executed sequentially.
1) Pedit - join: I will make line polyline.
2) Pedit-> Spline
3) Explode that polyline
Try this. It will take a Selection Set of Lines, turn them into a pline, spline it then explode it. Adjust fuzz to suit your need.
(defun c:test
( / pea fuzz ss
) fuzz 1.0e-6
(command "_PEDIT" "M" ss
"" "_J" fuzz
"_S" "") )
Thank you very much Dlanor!! :D
Can I know what is the fuzz? And how will it affect my polyline?
Actually I also wanted to add one more function in that lisp. I want to convert those exploded vertices back into polyline. Is that possible? Because after doing spline and explode,vertices in line will increase. For example 30 vertices will become 150
When you try to join two lines using pedit, it expects two ends to meet at a point, if they don't then it won't join them. It does however allow a fuzz factor. This is the amount by which two ends can differ but be accepted as the same i.e. a small gap between the ends of lines. Increasing the fuzz factor (making it larger) allows for bigger gaps but may alter the order lines are added.
I have set it at 1.0e-6 (0.000001).
Not sure I fully understand what you want. If you just want a polyline then don't explode it, it is a still a polyline object with spline fit curves, not a spline object.
Thanks for the explanation!
Actually I want these followings steps to happen in single lisp.
1. I will select amd give data points to a lisp
2. Pedit->Join
3. Pedit ->Spline
4. Explode
5.Pedit->join
I just want to add up the last 5th step in your previous lisp. So that I can make the the exploded points pline again
I'm missing something here.
Before you explode the line, it is a pline not a spline. By exploding and joining you will end up with the same pline you had before exploding. If you want the new vertices as points you need to use the 'coordinates property of the pline.
What exactly are you trying, as there may be an easier way of getting the end result
Also a tool by "(Gile)" to clean up those extra points!
https://www.theswamp.org/index.php?topic=19865.msg244892#msg244892
Dlanor I tried your lisp. But its not working. I'm getting this Invalid input
Select Lines :
Select entities or [FILter/Qselect]:
Entities in set: 1
Opposite corner:
Entities in set: 293
Command: _PEDIT
Select polyline to edit or [Multiple]: M
Select entities:
The entity selected is not a polyline. Turn it into one? [Yes/No] <Y> _JUnable to recognize entry. Please try again.
The entity selected is not a polyline. Turn it into one? [Yes/No] <Y> 0.000001Unable to recognize entry. Please try again.
The entity selected is not a polyline. Turn it into one? [Yes/No] <Y> _SUnable to recognize entry. Please try again.
The entity selected is not a polyline. Turn it into one? [Yes/No] <Y> Unable to recognize entry. Please try again.Invalid
Invalid input
Command: '_PMTHIST
Dlanor look at this explains what now is 5 individual posts trying to solve one problem.
http://www.theswamp.org/index.php?topic=55530.0
What this topic have to do with making curve smooth? I just want a lisp to combine multiple commands. Yes I did that mistake before and I'm not able to delete topics.
I have amended the code in my original post. I had forgotten to set peditaccept :opps:
Thanks a lot Dalanor it helped!! :D
You also need to remove fuzz near '_S' in this line (command "_PEDIT" "M" ss "" "_J" "_S" "")
