I just need a list of all of the blocks which have this "EPQMTAG" block in it.
(defun _listofblockswithnestedblock ( nested / lst name )
(vlax-for block (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)));for each block in drawing do the code
(if;if block is in layout, is xref and if is anonymous, skip to next block
(and
(= :vlax-false (vla-get-islayout block))
(= :vlax-false (vla-get-isxref block))
(not (wcmatch (setq name (vla-get-name block)) "`**"))
(vlax-for obj block;for all other blocks, do code
(and
(= "AcDbBlockReference" (vla-get-objectname obj))
(or
(and
(vlax-property-available-p obj 'effectivename)
(= (strcase nested) (strcase (vla-get-effectivename obj)))
);and
(= (strcase nested) (strcase (vla-get-name obj)))
);or
(not (member name lst))
);and
(setq lst (cons name lst))
);if
);vlax-for
);if
);vlax-for
lst
);defun
(defun LM:ss->ent ( ss / i l )
(if ss (repeat (setq i (sslength ss)) (setq l (cons (cdr (assoc 2 (entget (ssname ss (setq i (1- i)))))) l))))
);defun
;;;USE
(setq Allblocks (_listofblockswithnestedblock "EQPMTAG"))
(setq Allblocks (append (LM:ss->ent (ssget "_X" '((2 . "EQPMTAG")))) Allblocks))
;;;Thanks to J. Roper for this section:
;ATT:GETS - Utility routine to get all attributes for
;an insert object (EN).
;;You pass this function an entity name, like something that would be returned from this example:
;;(setq EN (car (entsel "\nSelect block")))
;;an entity name looks like this when returned on a command line --><Entity name: 4119ab90>
;;You use this function like this: (setq ATTLIST (ATT:GETS EN))
;;it returns a list like this ---> (("TAG1 . "VALUE1")("TAG2" . "VALUE2")....)
(defun ATT:GETS (EN / EL RES)
;entnext goes on to the next entity. If what you passed is an attributed block, the next entity will be an attribute.
(setq EN (entnext EN)
EL (entget EN));entget "breaks open" the entity name to reveal the entity list
(while (= "ATTRIB" (cdr (assoc 0 EL)));we check the entity list to see if it is an attribute
(setq RES (cons
(cons (cdr (assoc 2 EL));if it is, we create a list of its tag and value, dxf code 2 and 1, using CONS
(cdr (assoc 1 EL))) RES)
EN (entnext EN);go to the next entity
EL (entget EN)));get the next entities list
(reverse RES);reverse the list to put it in proper order.
(and
(and
(or
(and
);and
);or
);and
;;; (setq lst (cons name lst))
;;; (setq lst (cons (vlax-vla-object->ename obj) lst))
;;; (setq lst (cons (ATT:GETS (vlax-vla-object->ename obj)) lst))
;;; (setq lst (cons (car (ATT:GETS (vlax-vla-object->ename obj))) lst))
(setq lst (cons (cdar (ATT:GETS (vlax-vla-object->ename obj))) lst)) ;;;ATT:GETS is a sub-routine I use to get attribute info.
;;;(setq lst (cons (cdar (ATT:GETS (car (entsel)))) lst))
);if
);vlax-for
);if
);vlax-for
lst
);defun
;;; (if ss (repeat (setq i (sslength ss)) (setq l (cons (cdr (assoc 2 (entget (ssname ss (setq i (1- i)))))) l))))
(if ss (repeat (setq i (sslength ss)) (setq l (cons (cdar (ATT:GETS (ssname ss (setq i (1- i))))) l))))
);defun
;;;USE
