Author Topic: Area of Hatch  (Read 1501 times)
M-dub
Area of Hatch
« on: April 02, 2008, 08:18:38 PM »
This might sound like a newbie question, but I've never needed this before...
Is there a way to find out what the area that a hatch covers is?  I have a bunch of closed polylines with islands inside that are not included in the hatch.  I was hoping not to have to calculate the area of each of the islands and subtract them from the main hatched area.
Does that make sense?
Re: Area of Hatch
« Reply #1 on: April 02, 2008, 08:21:04 PM »
LIST it:
Command: li LIST
Select objects: l
1 found
Select objects:
                  HATCH     Layer: "ORIZONT - 0.5"
                            Space: Model space
                   Color: 1 (red)    Linetype: "BYLAYER"
Linetype scaling =       100
                   Handle = 4ac0
                 Hatch pattern SOLID
                 Associative
                 Area      733368
                 Origin    X=        0  Y=        0  Z=        0
M-dub
Re: Area of Hatch
« Reply #2 on: April 02, 2008, 08:22:38 PM »
I knew it... (If only we had 2008 installed...)
That's the first thing I tried and this is all I get.  Boo Hoo....
Command: li LIST 1 found
                  HATCH     Layer: "WEEDS_STERILIZE"
                            Space: Model space
                   Handle = 231A3
                 Hatch pattern ANSI31
                 Hatch scale    5.0000
                 Hatch angle 0d0'0"
                 Associative
M-dub
Re: Area of Hatch
« Reply #3 on: April 02, 2008, 08:42:04 PM »
This gem will help me out a bit for now.  I'll try to modify it tomorrow.
http://www.theswamp.org/index.php?topic=8595.0
Krushert
  • FREE BEER Tomorrow!!
Re: Area of Hatch
« Reply #4 on: April 03, 2008, 07:04:04 PM »
 :wink:
**Edit**
It returns a value of just the hatch (meaning it subtracts the islands/holes from the whole).
what is also great is that will sum the areas of the hatches selected.
« Last Edit: April 03, 2008, 07:10:42 PM by Krushert »
Bryco
Re: Area of Hatch
« Reply #5 on: April 03, 2008, 09:26:13 PM »
There is also the clunky area command where you add and subtract areas
