Author Topic: layer dia box 'gone awol'  (Read 4434 times)
Big G
« on: November 25, 2005, 10:15:08 AM »
After a power cut last night the layer properties dia box has disappeared. I CTRL-ALT-DEL my machine weeknights and this was the case last nite.
All the other dia boxes are working fine just the layer one is AWOL.
Anyone experienced this before?? Or anyone know of a rememdy?
Ive tried changing the desktop size to see if its moved out of the screen area, but the res is set to 1280 x 1024 (max)
Short of a reinstall im stumped?
TaVM guys and gals
Big G
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
M-dub
Re: layer dia box 'gone awol'
« Reply #1 on: November 25, 2005, 10:18:21 AM »
DDLMODES doesn't do anything? (No error message?)
Big G
« Reply #2 on: November 25, 2005, 10:21:10 AM »
thats missing too.....
the acad bar lightens up (as if to switch to the new window) which doesnt appear.
The command starts, but no dcl...hitting esc still does stop the command and return to the main drg window.
LE
« Reply #3 on: November 25, 2005, 10:25:47 AM »
DCL ?.... what autocad version you are using ?
Check if
FILEDIA = 1
Big G
« Reply #4 on: November 25, 2005, 10:27:43 AM »
already been there LE - am running 2K6 Map3D
have been for months without (too many) problems
LE
« Reply #5 on: November 25, 2005, 10:32:07 AM »
Try this:
Command: (initdia)(command "_.layer")
Big G
« Reply #6 on: November 25, 2005, 10:35:34 AM »
nada again....i can see at the bottom that its trying to run thru the layers in the drawing (blue bar charges up @ co-ords)
M-dub
« Reply #7 on: November 25, 2005, 10:37:55 AM »
You still get options if you type in -LA on the command line?
Big G
« Reply #8 on: November 25, 2005, 10:41:26 AM »
yeah m-dub...everthing as normal.
-layer still pops up all the usual. just no dia box.
*EDIT*
Is there a cmd to reset the position of ALL the dia boxes?
M-dub
« Reply #9 on: November 25, 2005, 10:42:22 AM »
.layer
Big G
« Reply #10 on: November 25, 2005, 10:43:56 AM »
.layer
nada
Dinosaur
« Reply #11 on: November 25, 2005, 10:47:52 AM »
Before a full reinstall, you should consider a repair install.  These seem to be more successful than with previous releases and thankfully so.  With Civil 3D 2006 a repair install is a bi-weekly affair when commands go missing.
M-dub
« Reply #12 on: November 25, 2005, 10:48:03 AM »
Hmmm....
(shot in the dark)
cmddia?
Big G
« Reply #13 on: November 25, 2005, 10:49:41 AM »
cmddia = 1
looks like a 'repair' then?
I assume ill lose ALL my custom menus and macros then?
M-dub
« Reply #14 on: November 25, 2005, 10:51:09 AM »
Not if you back them up first!
