Author Topic: PDF Software  (Read 10414 times)
CaddmannQ
Re: PDF Software
« Reply #15 on: July 24, 2007, 06:40:40 PM »
Go try & zip a zip file & you'll figure it out.  ;-)
<Edit: Because the danged "A" key is sticking on my keyboard.>
« Last Edit: July 24, 2007, 06:44:36 PM by CaddmannQ »
Josh Nieman
Re: PDF Software
« Reply #16 on: July 24, 2007, 07:12:30 PM »
hehe... zip a zip... now that's just FUN to SAY.
...it's been a long day.
daron
Re: PDF Software
« Reply #17 on: July 24, 2007, 10:56:49 PM »
Out of curiosity, what are all these PDF's you're making made from?
The only time I do a PDF is from AutoCAD, & then I just "plot to PDF".
Not sure who you're asking, but with CutePDF I can print word documents, excel, notepad, most anything software related. It's set up as a printer object. So, mine's made from CutePDF.
M-dub
Re: PDF Software
« Reply #18 on: July 25, 2007, 08:57:56 AM »
We use PrimoPDF, CutePDF and Adobe Acrobat 7.0 Pro depending on who's machine you're on.  Don't really have too many problems with any of them.  We need (and pay for) Acrobat because we need to modify PDF's from time to time.  If I had to chose one, it would have to be Acrobat...
CaddmannQ
Re: PDF Software
« Reply #19 on: July 25, 2007, 09:39:55 AM »
Not sure who you're asking...
Anybody with an answer  :wink:
I've never been big on PDF's, and I guess I'm just looking for more rationale to like/use them.
Re: PDF Software
« Reply #20 on: July 25, 2007, 09:42:10 AM »
We use PDF 995 at work but I use Acrobat Pro at home and prefer it.
Re: PDF Software
« Reply #21 on: July 25, 2007, 09:56:07 AM »
Th reason we use them is because frequently we have to provide a set of plans for review to owners, builders, contractors etc. More often than not, in fact in the many years I have been doing this it has happened only once, these people do not have AutoCAD and it is problematic for many to ask that they go to autodesk and download a viewer that will need to be updated whenever the drawing format changes. However, almost everyone has the free adobe reader installed on their system. Most computers come with it pre-installed. For that reason alone, it makes more sense to provide a PDF. Also, whenever we provide a plot set to any printer, they can easily plot the files without having to install any special software. The files look exactly like they are supposed to every time.
daron
Re: PDF Software
« Reply #22 on: July 25, 2007, 10:03:18 AM »
Like and Use are two different things. It's a matter of giving in to the machine. Everybody has adobe reader. Everyone wants it in PDF format. That's why I use it. There are some reasons to like it. Sending a document from windows to unix and back helps to keep the format better than OO does for one. I'm sure there are more, I just don't have them. Really though, it's like asking why we use Autocad? Well, it's the standard. Everyone knows about it. You can't get away from it.
CaddmannQ
Re: PDF Software
« Reply #23 on: July 25, 2007, 12:23:37 PM »
Point taken, and I understand the need for platform independence, but my best tool is a hammer so I tend to see every job as a nail.  :wink:
I guess I'm just a bit PO'd that the SE's at the state architect are now demanding PDF's for checking, while record sets must still be in DWG format. PDF is not what I consider an engineer's tool, but rather a literary/publisher's tool. Anyhow, it's just extra work for us with no compensation. I guess I was just reaching for any idea that would imply an advantage/compensation for us, as the designers.
Re: PDF Software
« Reply #24 on: July 25, 2007, 12:35:34 PM »
I see it as being no different than plotting a set. If I plot a set to PDF that is essentially the same as me plotting a set to paper .. 'ceptin it is less work to do a PDF
Dinosaur
Re: PDF Software
« Reply #25 on: July 25, 2007, 12:56:08 PM »
Expanding on Keith's comment about recipients not having AutoCAD, now having AutoCAD is not necessarily enough.  If a drawing is created with a vertical application such as ADT or Civil 3D, unless the correct object enabler is installed AutoCAD can not display many key parts of the drawing.
Antisthenes
Re: PDF Software
« Reply #26 on: July 30, 2007, 02:22:23 PM »
Josh Nieman
Re: PDF Software
« Reply #27 on: July 30, 2007, 02:23:55 PM »
PDF creator  because it's opensource
http://www.pdfforge.org/products/pdfcreator/
http://pdfcreator.sf.net
and flawed.
That's the first PDF Creator my company went with... we quickly ditched it after so much money being lost having to get reprints done using a NON sucky pdf maker.
Chuck Gabriel
Re: PDF Software
« Reply #28 on: July 30, 2007, 02:58:28 PM »
and flawed.
I've been using it for several years now without any problems, although it did take some trial and error to get it configured just right.  What issues did you have with it?
Josh Nieman
Re: PDF Software
« Reply #29 on: July 30, 2007, 03:07:01 PM »
and flawed.
Inconsistent lineweight printing, plotting shades/hatches/wipeouts as solid black polygons at times, and it didn't like our shaded lines too much, because it always made them like 50% lighter than they shoulda been.  This could have been due to the pdfs made by this driver not having a good relationship with whatever conversion our outside printers' use, but either way, it wasn't working out.
The boss had it from the old company he worked at, and I think there was a guy there who set it up right, and it wasn't working well over here... I had no clue what it was really until I read about it recently.  It was the bosses' baby and when he couldn't get it to work right, I provided a reliable, efficient, cost effective solution that anyone could use.
