Author Topic: (Microstation) Width of a Smartline  (Read 8975 times)
PHX cadie
« on: August 27, 2007, 06:24:01 PM »
I'm working a dgn file that has been converted from AutoCad.
My best guess is the plines have been given a width, because now in MS when I place a smartline it is ~ 1/8" thick. I don't see any options on smartline, when placing or under element format.
How do I get the smartlines back to 0 width?
Acad 2013 and XM
kindra
Re: Width of a Smartline
« Reply #1 on: August 28, 2007, 01:59:27 PM »
Just a guess....
If you go under Element-Line Styles-Custom, you can change the origin and end width of lines (this is also where to change the scaling of line styles).
Let me know if this works out - this is a problem I have not yet run into, but we do our fair share of conversion work here, and I'm interested.
LE
« Reply #2 on: August 28, 2007, 02:05:21 PM »
Don't know.... but I remember when using IMS 4.0 and 5.0 - there was a little letter size manual with all the short cuts and descriptions of each command.... sorry, all what I did in this app..... is 100% forgot/lost...
BTW, are you the only one in your office using this app?
PHX cadie
« Reply #3 on: August 28, 2007, 02:47:27 PM »
Awesome! Thanks.
I did notice the Element Line Styles, but never thought of..........plines as "custom". Thats the ticket!
No I'm one of ~15. Most  new to MS except the Boss and he is pretty busy, but thanks for the reply. I was gettin lonely  :-D
Acad 2013 and XM
kindra
« Reply #4 on: August 28, 2007, 03:32:19 PM »
No problem atall. I'm just glad I could help someone else, being as that I'm usually on the receiving end of said help.
And you're right, it does get pretty lonely in here.
*pauses to watch tumbleweeds blow by*
Maverick®
« Reply #5 on: August 28, 2007, 04:35:44 PM »
*chases after tumbleweed wearing a pirate hat and Dutch wood clogs*
Arizona
« Reply #6 on: August 28, 2007, 07:38:57 PM »
With a wooden leg?
kindra
« Reply #7 on: August 29, 2007, 04:46:22 PM »
must.....resist.....mental.....image......
Maverick®
« Reply #8 on: August 29, 2007, 05:25:12 PM »
With a wooden leg?
  Tumbleweeds don't have legs.
  If you meant me.......
 Must ...... resist...... joke.....
Arizona
« Reply #9 on: August 29, 2007, 06:41:44 PM »
With a wooden leg?
Oh, go ahead... :-)
M-dub
« Reply #10 on: August 29, 2007, 09:01:16 PM »
Good Luck! He had me at "*chases after tumbleweed..."  :-D
Maverick®
« Reply #11 on: August 30, 2007, 10:03:21 AM »
Did I mention I once dated this hippy girl named Tumbleweed?   :lmao:
Arizona
« Reply #12 on: August 30, 2007, 10:13:07 AM »
Now it's my turn to resist any comments regarding... rolling tumbleweeds... :-)
kindra
« Reply #13 on: August 31, 2007, 11:18:36 AM »
 :lmao: :lmao: :lmao: :lmao:
PHX cadie
« Reply #14 on: March 11, 2009, 03:19:29 PM »
OK, months later and now I need the reverse.
Going back to element>line styles custom and setting the "continuous" to a origin and end width of 5' is not working
How would one draw a line 5' in width?  (Showing asphalt in profile, exaggerated scale)
Acad 2013 and XM
