Author Topic: Coordinates in the triangle  (Read 7077 times)
velasquez
Re: Coordinates in the triangle
« Reply #15 on: October 16, 2018, 06:15:51 PM »
Nicely done Lee, direct and concise...
This one works for any 3d points
Thanks Stefan, in hindsight that makes more sense.  :wink:
Interesting stuff, no doubt. But I don't understand. I see a green and a yellow line that are not parallel to any of the magenta lines.
The yellow line and a green line are to show the location of the coordinates that I need to find. The angle between these lines is always 90 degrees.
I assumed that P3-P1 was parallel to P2-XPTO; without this assumption, any point on the circle with diameter P1-P2 meets your criteria -
Hence there would be infinite solutions, as kirby correctly notes.
Hello lee
Is there a way to find just the point at the intersection of the lines that I marked in your image?
« Reply #16 on: October 16, 2018, 06:31:44 PM »
Hello lee
Assuming the orange horizontal line is parallel to the base of the triangle, this is what my code (and Stefan's code) will give you.
velasquez
« Reply #17 on: October 17, 2018, 08:48:38 AM »
Hello lee
Hello Lee
Assuming the base of the triangle is not parallel to the orange horizontal line how can I compute the xpto point?
ribarm
  • Marko Ribar, architect
« Reply #18 on: October 17, 2018, 09:17:13 AM »
(setq xpto (list (car p1) (cadr p2)))
(princ xpto)
M.R. on Youtube
« Reply #19 on: October 17, 2018, 09:38:25 AM »
(princ xpto)
I thought the same thing too but from the other examples it won't work.
« Reply #20 on: October 17, 2018, 12:42:13 PM »
Then the problem requires additional constraints - please refer to my earlier post.
velasquez
« Reply #21 on: October 17, 2018, 04:37:54 PM »
Thank you to everyone who helped me.
