Author Topic: Coordinates in the triangle  (Read 7075 times)
velasquez
« on: October 16, 2018, 08:02:56 AM »
I have problem to calculate the coordinates of the point "xpto" in the triangle.
Can someone help me?
Tanks.
Re: Coordinates in the triangle
« Reply #1 on: October 16, 2018, 08:15:18 AM »
"Cheating" with trans:
  1. (defun tpt ( p1 p2 p3 / v )
  2.     (setq v (mapcar '- p3 p1))
  3.     (trans (cons (car (trans p2 0 v)) (cdr (trans p1 0 v))) v 0)
  4. )
  5.
Assumes points are in WCS; compatible with UCS planes parallel to WCS plane only.
Marc'Antonio Alessi
  • Marco
« Reply #2 on: October 16, 2018, 08:30:21 AM »
  4. )
  5.
:)  Grande.
ribarm
  • Marko Ribar, architect
« Reply #3 on: October 16, 2018, 08:48:52 AM »
Another convoluted though and untested...
  1. (defun c:test ( / v^v projp2pp xpto p1 p2 p3 pt )
  2.
  3.   (defun v^v ( u v )
  4.     (list
  5.       (- (* (cadr u) (caddr v)) (* (caddr u) (cadr v)))
  6.       (- (* (caddr u) (car v)) (* (car u) (caddr v)))
  7.       (- (* (car u) (cadr v)) (* (cadr u) (car v)))
  8.     )
  9.   )
  10.
  11.   (defun projp2pp ( p p1 p2 / v nv n )
  12.     (setq v (mapcar '- p2 p1))
  13.     (setq nv (v^v (mapcar '- p p1) (mapcar '- p p2)))
  14.     (setq n (v^v v nv))
  15.     (inters p (mapcar '+ p n) p1 p2 nil)
  16.   )
  17.
  18.   (defun xpto ( p1 p2 p3 / pp )
  19.     (setq pp (projp2pp p2 p1 p3))
  20.     (mapcar '+ p1 (mapcar '- p2 pp))
  21.   )
  22.
  23.   (initget 1)
  24.   (setq p1 (trans (getpoint "\nP1 : ") 1 0))
  25.   (initget 1)
  26.   (setq p2 (trans (getpoint "\nP2 : ") 1 0))
  27.   (initget 1)
  28.   (setq p3 (trans (getpoint "\nP3 : ") 1 0))
  29.   (setq pt (xpto p1 p2 p3))
  30.   (entmake (list '(0 . "POINT") (cons 10 pt)))
  31.   (princ)
  32. )
  33.
M.R. on Youtube
roy_043
  • BricsCAD 18
« Reply #4 on: October 16, 2018, 09:26:12 AM »
Interesting stuff, no doubt. But I don't understand. I see a green and a yellow line that are not parallel to any of the magenta lines.
velasquez
« Reply #5 on: October 16, 2018, 10:08:24 AM »
Hello Roy
The yellow line and a green line are to show the location of the coordinates that I need to find. The angle between these lines is always 90 degrees.
roy_043
  • BricsCAD 18
« Reply #6 on: October 16, 2018, 10:35:00 AM »
Hello Roy
I guessed as much. But the other contributors have made the assumption that the green line is parallel to a magenta line. Conclusion: your image is quite confusing.
Stefan
« Reply #7 on: October 16, 2018, 12:25:49 PM »
  4. )
  5.
Nicely done Lee, direct and concise...
This one works for any 3d points
  1.     (setq v (mapcar '- p3 p1)
  2.           p1 (trans p1 0 v)
  3.           p2 (trans p2 0 v)
  4.     )
  5.     (trans (list (car p2) (cadr p2) (caddr p1)) v 0)
velasquez
« Reply #8 on: October 16, 2018, 01:28:16 PM »
I'm sorry if the picture was confusing.
The functions always return the coordinate of p2, I need to find out the coordinate of the xpto point.
Remembering that I always have p1 p2 and p3. I posted a drawing showing some triangle situations.
Tanks.
ribarm
« Reply #9 on: October 16, 2018, 01:41:36 PM »
So...
Cyan line is not parallel to p1p3 line?
Then how do you get cyan?
M.R. on Youtube
kirby
« Reply #10 on: October 16, 2018, 02:01:05 PM »
There are an infinite number of rays from P1 and P2 that are perpendicular to each other.  You need to add another constraint (eg. ray from P1 is parallel to X axis, etc.)
velasquez
« Reply #11 on: October 16, 2018, 02:53:55 PM »
The point you need to calculate is always the projection from point p1 to the projection of point p2 at an angle of 90 degrees.
« Last Edit: October 16, 2018, 03:00:00 PM by velasquez »
ribarm
« Reply #12 on: October 16, 2018, 03:10:50 PM »
Men, like Kirby explained, there are infinite number of possibilities of such projections - you don't say at which orientation is either cyan or perpendicular projection... Just create half circle from p1 to p2... All points on that half circle could be xpto point + half circle can rotate in 3d around p1 p2 axis which makes it sphere of infinite xpto points on its surface...
M.R. on Youtube
velasquez
« Reply #13 on: October 16, 2018, 03:25:57 PM »
Hello Ribarm,
Please note the drawing I posted, what I need is to learn to calculate the coordinate of the point described as xpto, in relation to the x and y axes.
Using the id command at the end of the green line will show this.
I'm sorry but I can not show it better.
« Reply #14 on: October 16, 2018, 05:19:51 PM »
Thanks Stefan, in hindsight that makes more sense.  :wink:
I assumed that P3-P1 was parallel to P2-XPTO; without this assumption, any point on the circle with diameter P1-P2 meets your criteria -
Hence there would be infinite solutions, as kirby correctly notes.
