Author Topic: Store Data in AUTOCAD file  (Read 7127 times)
mailmaverick
« on: March 04, 2015, 12:00:22 PM »
Dear All,
I want to store some data in AUTOCAD file. For example, as soon as an AUTOCAD file is opened on any computer, the computer name, date and time must be recorded automatically. When the same file is opened in another computer, the same information must be stored in addition to the earlier information.
Also, this information must be hidden from the users of the file but should be retrievable by me using LISP.
How to do so ?
Re: Store Data in AUTOCAD file
« Reply #1 on: March 04, 2015, 12:04:37 PM »
You could use xdata.
snownut2
  • Bricscad 22 Ultimate
« Reply #2 on: March 04, 2015, 12:06:49 PM »
Do a search here on use of dictionaries, could be a very easy task to accomplish.
You will need to load a lisp function in your acad.lsp startup function, so to get it to work on computers outside your control will be tough to accomplish.
« Reply #4 on: March 04, 2015, 12:36:05 PM »
Here's a concept Modification Logging Utility that I wrote as an example quite recently - it may give you some ideas.
Lee
mailmaverick
« Reply #5 on: March 04, 2015, 01:03:12 PM »
Lee
Excellent Lee !!! This is quite similar to what I wanted. Once again, Lee to the rescue.
I have seen that you have used Group Code -3. How come we can use a negative Group Code ?
Also, apart from -3, what other Group Codes can we assign to an entity which do not interfere with the AUTOCAD's predefined group codes ?
Also, you have assigned the data to an entity. How can we assign the data to a drawing file (not an entity).
« Reply #6 on: March 04, 2015, 02:30:27 PM »
Here's another .. you can choose what you'd like the data written to. My example writes to layer 0.
  1. (defun _xdatalogger (ename appname / data el)
  2.   (if (and (= 1 (getvar 'dwgtitled))
  3.            (= (type ename) 'ename)
  4.            (or (tblobjname "APPID" appname) (regapp appname))
  5.            (setq el (entget ename (list appname)))
  6.       )
  7.     (progn
  8.       (setq data (strcase (strcat (getenv "computername")
  9.                                   "_"
  10.                                   (getenv "username")
  11.                                   "_"
  12.                                   (rtos (getvar 'cdate) 2 4)
  13.                           )
  14.                  )
  15.       )
  16.       (if (not (wcmatch (vl-princ-to-string (cdr (assoc -3 el))) (strcat "*" data "*")))
  17.         (entmod
  18.           (append
  19.             (vl-remove (assoc -3 el) el)
  20.             (list (list -3 (append (list appname) (list (cons 1000 data)) (cdadr (assoc -3 el)))))
  21.           )
  22.         )
  23.       )
  24.     )
  25.   )
  26.   (princ)
  27. )
  28. (defun _readxdatalogger (ename appname)
  29.   (if (= (type ename) 'ename)
  30.     (mapcar 'print (mapcar 'cdr (cdadr (assoc -3 (entget ename (list appname))))))
  31.   )
  32. )
  33. ;; Log to layer 0
  34. (_xdatalogger (tblobjname "layer" "0") "MyDataLogger")
  35. ;; Read data
  36. (_readxdatalogger (tblobjname "layer" "0") "MyDataLogger")
  37.
« Last Edit: March 04, 2015, 03:12:40 PM by ronjonp »
mailmaverick
« Reply #7 on: March 04, 2015, 03:37:39 PM »
Dear RONJONP, I am confused by your LISP.
Please explain how can we write data to a layer when a layer is not an entity like a circle, polyline etc.
« Reply #9 on: March 04, 2015, 03:52:52 PM »
Quote from: mailmaverick
I thought you wanted to write the data to the "drawing" .. figured layer 0 is part of every drawing so I used it as an example. It does not have to be layer 0 that you write to. The function gives you flexibility to write to whatever makes you happy. :)
« Last Edit: March 04, 2015, 03:58:48 PM by ronjonp »
« Reply #10 on: March 04, 2015, 05:52:51 PM »
Lee
You're most welcome  :-)
All Extended Entity Data (xData) is stored under DXF group -3; I would recommend that you first read up on xData, perhaps starting here.
For this I would personally use a dictionary defined under the Named Object Dictionary (namedobjdict)
« Reply #11 on: March 04, 2015, 11:54:49 PM »
I was thinking that too but after a quick test, the data gets lost if the drawing is wblocked.  :|
« Reply #12 on: March 05, 2015, 12:36:46 AM »
Not if you make it hard owned. Search the swamp for same. :)
mailmaverick
« Reply #13 on: March 05, 2015, 04:28:43 AM »
Thanks to Lee for all his inputs.
Dear Ron, I agree that I want to write the data to a drawing and not an entity. But i did not know that you can write data to a layer also. In that case, can we write such datas to Dimension Styles, Text Styles etc ?
Is there any comprehensive list of AUTOCAD objects which support data writing ? If any link is available, please let me know.
« Reply #14 on: March 05, 2015, 09:02:17 AM »
There is a list of supported objects in the HELP file :)
Quote from: AutoCAD Help File
object
Type: All drawing objects, AttributeReference, Block, Dictionary, Dimension, DimStyle, Group, Layer, Layout, Linetype, Material, MLeaderStyle, PlotConfiguration, RegisteredApplication, TableStyle, TextStyle, UCS, View, Viewport, XRecord
The object this method applies to.
