Author Topic: character or number  (Read 1927 times)
TopoWAR
character or number
« on: April 08, 2012, 07:43:48 PM »
hello, as if the string is a number or character (letter)
example:
(setq x "b" x1 "1")I need a command that I distinguish between number and letter,
something like dos_strischar of DOSLib but in AutoLISP
thanks
Thanks for help
Re: character or number
« Reply #1 on: April 08, 2012, 08:31:13 PM »
(wcmatch <string> "@")
(wcmatch <string> "#")
(type (read <string>))
(< 47 (ascii <string>) 58)
(vl-every '(lambda ( c ) (< 47 c 58)) (vl-string->list <string>))
(distof <string>)
« Last Edit: April 08, 2012, 08:34:33 PM by Lee Mac »
« Reply #2 on: April 08, 2012, 08:31:47 PM »
  1. (numberp (read x1))
TopoWAR
« Reply #3 on: April 08, 2012, 08:33:31 PM »
thank you very much, teachers :-D
Thanks for help
« Reply #4 on: April 09, 2012, 07:58:19 AM »
Has anyone seen the cat?  :evil:
alanjt
  • Standby for witty remark...
« Reply #5 on: April 09, 2012, 12:44:23 PM »
Dropbox
