Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
intersect line draw
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: intersect line draw (Read 1483 times)
dussla
Bull Frog
intersect line draw
on:
May 05, 2012, 08:19:55 PM »
sorry sorry for many ask
really sorry
i am making patter line
if you see my attached file . you can understand my work
in my work , that pattern is used often
it is difficult to make that pattern withmy poor lisp skill
pls can you make me that lisp
Logged
irneb
Water Moccasin
ACad R9-2016, Revit Arch 6-2016
WWW
Re: intersect line draw
Reply #1 on:
May 06, 2012, 07:43:34 AM »
Try this one:
Code - Auto/Visual Lisp:
[Select]
vl-load-com
defun
c:PatternLine
p1 p2 ss en par baseline dir wid ptlst n pt
if
and
setq
p1
getpoint
"Pick 1st point of crossing line: "
setq
p2
getpoint
p1
"Pick 2nd point of crossing line: "
setq
ss
ssget
"_F"
list
p1 p2
0
"LWPOLYLINE"
progn
setq
ss
ssnamex
ss
en
cadar
ss
par
vlax-curve-getParamAtPoint
en
cadr
cadddr
car
ss
wid
vlax-curve-getDistAtParam
en
1+
fix
par
en
fix
par
2
dir
apply
angle
list
vlax-curve-getPointAtParam
en par
en
if
par
fix
par
0.5
fix
par
1+
fix
par
baseline
list
polar
p1 dir wid
polar
p2 dir wid
n
0
ptlst
list
car
baseline
foreach
lst ss
setq
en
cadr
lst
pt
vlax-curve-getClosestPointTo
en
cadr
cadddr
lst
t
p1
apply
inters
append
baseline
list
pt
polar
pt dir wid
p2
polar
p1 dir wid
ptlst
if
rem
n
2
0
cons
p2
cons
p1 ptlst
cons
p1
cons
p2 ptlst
n
1+
n
setq
ptlst
cons
if
rem
n
2
0
cadr
baseline
polar
cadr
baseline
dir wid
ptlst
entmake
append
0
"LWPOLYLINE"
100
"AcDbEntity"
list
cons
67
if
getvar
'CVport
1
0
1
cons
8
getvar
'CLayer
100
"AcDbPolyline"
list
cons
90
length
ptlst
70
0
43
0.0
38
0.0
39
0.0
apply
append
mapcar
lambda
pt
cons
cons
10
pt
40
0.0
41
0.0
42
0.0
91
0
reverse
ptlst
210
0.0
0.0
1.0
princ
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
intersect line draw
