Author Topic: Extract Portion of polyline without exploding  (Read 3939 times)
matrix2005in
« on: May 29, 2006, 01:50:55 PM »
hi
any one know how to extract a portion of main polyline wiout exploding the same....  8-)
thanks
mathew
Re: Extract Portion of polyline without exploding
« Reply #1 on: May 29, 2006, 03:47:39 PM »
Sure, by using some of the curve functions. :-)
vlax-curve-getArea
vlax-curve-getClosestPointTo
vlax-curve-getClosestPointToProjection
vlax-curve-getDistAtParam
vlax-curve-getDistAtPoint
vlax-curve-getEndParam
vlax-curve-getEndPoint
vlax-curve-getFirstDeriv
vlax-curve-getParamAtDist
vlax-curve-getParamAtPoint
vlax-curve-getPointAtDist
vlax-curve-getPointAtParam
vlax-curve-getSecondDeriv
vlax-curve-getStartParam
vlax-curve-getStartPoint
matrix2005in
« Reply #2 on: May 30, 2006, 02:10:29 AM »
Hi CAB
if you dont mind can you give it to me in full form..i mean a complete lisp....i am not that good to creat myself..thats why..
thanks
Jürg Menzi
  • Oberegg, Switzerland
« Reply #3 on: May 30, 2006, 02:32:04 AM »
Visit my homepage -> Free Stuff -> Free Programs and search for 'CopyPlineSeg.lsp'...
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
matrix2005in
« Reply #4 on: May 30, 2006, 10:42:28 AM »
oh gr8 one....
but that will only extract one segment...i want select two point anywhere in polyline and extract that portion.....
any hope?/
thanks
Jürg Menzi
« Reply #5 on: May 31, 2006, 11:19:29 AM »
Sorry for the delay...
I had to rewrite some functions from another project to create this one:
CopyPlineSection
« Reply #6 on: May 31, 2006, 02:12:21 PM »
Here is my quickie method.
Copies from the point of two pick points then allows the user to past the new pline.
;;  Copy a user selected section of a pline
;;  CAB 05/31/06
;;  Pick 2 clip points then pick new location for new pline
(defun c:plineclip (/ end1 end2 endpt p1 p2 pk1 pk2 strpt)
  (command "._undo" "_begin")
  (if (and
        (setq pk1 (entsel "\nPick pline trim point."))
        (setq pk2 (entsel "\nPick second pline trim point."))
        (eq (car pk1) (car pk2))
        (setq ent1 (car pk1))
        (setq p1 (vlax-curve-getclosestpointto (car pk1) (cadr pk1)))
        (setq p2 (vlax-curve-getclosestpointto (car pk2) (cadr pk2)))
        (setq endpt (vlax-curve-getendpoint (car pk1)))
        (setq strpt (vlax-curve-getstartpoint (car pk1)))
        (if (< (vlax-curve-getdistatpoint (car pk1) p1)
               (vlax-curve-getdistatpoint (car pk2) p2)
          (setq end1 strpt end2 endpt)
          (setq end2 strpt end1 endpt)
      (command "._copybase" "_non" p1 ent1 "")
      (command "._break" (list ent1 p1) end1)
      (command "._break" (list ent1 p2) end2)
      (command "._pasteclip" "_non" p1)
      (command "._move" ent1 "" p2 pause)
      (command "._undo" "_end")
(prompt "\nCopy Pline section Loaded, Enter PlineClip to run.")
« Last Edit: June 01, 2006, 12:01:13 AM by CAB »
LE
« Reply #7 on: May 31, 2006, 02:27:51 PM »
NICE one!
GDF
« Reply #8 on: May 31, 2006, 02:47:46 PM »
NICE one!
Alan
Vey very nice!
Gary
« Reply #9 on: May 31, 2006, 02:51:56 PM »
Well thank you both. :)
I revised it to this so if the user hits escape there will not be a copy left in the drawing.
;;  CAB 05/31/06
  (if (and
      (command "._copybase" "_non" p2 ent1 "")
      (entdel ent1)
      (command "._pasteclip" "_non" pause)
« Last Edit: June 01, 2006, 12:00:50 AM by CAB »
matrix2005in
« Reply #10 on: May 31, 2006, 10:47:24 PM »
HI CAB that was excellent
One main problem is this wont work with autoCAD 2000i...can you revise to make compatible with it..
thanks
matrix2005in
« Reply #11 on: May 31, 2006, 10:54:59 PM »
HI Jürg Menzi
Sory i forgot to mention you ...in your code it gives alert if below AuotCAD 2004
can you enable this to work in AUtoCAD 2000i tooo
thanks
« Reply #12 on: May 31, 2006, 11:59:50 PM »
thanks
I'm running it in ACAD2000, what problem did you have?
Edit: Try to copy it again, I added (vl-load-com)
Some systems do not load this on startup.
matrix2005in
« Reply #13 on: June 01, 2006, 12:45:25 AM »
HI CAB
sorry boss....actually i dont know what happend it works fine with other machines which installed 2000i
thanks man
i will ask more help if you dont mind
Jürg Menzi
« Reply #14 on: June 02, 2006, 04:47:43 AM »
I've upload a new version which supports A2k+...
