Until recently, when I dock my command line I get nine lines displaying. I used to be able to drag an edge to resize it. I seem to have lost that ability and can't find the variable to assign a number of lines.
Hold control while hovering over the top of command line.
Quote from: ChrisCarlson on March 02, 2016, 09:53:58 AMHold control while hovering over the top of command line. That does nothing.
Quote from: Rob... on March 02, 2016, 09:56:05 AMQuote from: ChrisCarlson on March 02, 2016, 09:53:58 AMHold control while hovering over the top of command line. That does nothing.Try ALT+F4. Any luck?
Solution:Dock at bottom, re-size, and move to the top.
I too have my command line docked along the top (below the ribbon) and have experienced the same lack of resizing capabilities. I think I've redone it enough times that it's finally holding but it was moving around constantly after a restart. The CUI customization and workspace don't seem to save the desired settings as expected.
