Author Topic: Next and Previous dwg in directory  (Read 8180 times)
GDF
« on: March 18, 2008, 02:33:21 PM »
Tim (or anyone else can jump in here)
Ever so often when using these routines, it cases AutoCAD to lockup.
Is it because of AcadApplication.Documents.Open function (just quessing)?
I'm using AutoCAD 2008 on Windows XP
But when it does happen, it gets to be annoying. Has anyone else experienced this problem...if so, how to fix it.
I use these two routines hundreds of times a day...so I cannot live without them.
Gary
;;;by Tim Willey
(defun MyNext  (/ AcadObj DocCol DirPath DwgList Pos Dwg DwgFile ErrChk Opt)
    ; Opens/Makes-active next drawing in the directory.
  (setq AcadObj (vlax-get-Acad-Object))
  (setq DocCol (vla-get-Documents AcadObj))
  (setq DirPath (getvar "dwgprefix"))
  (setq DwgList (vl-directory-files DirPath "*.dwg" 1))
  (setq DwgList (vl-sort DwgList '<))
  (setq Pos (vl-position (getvar "dwgname") DwgList))
  (if (setq Dwg (nth (1+ Pos) DwgList))
    (progn (setq DwgFile (strcat DirPath Dwg))
           (setq ErrChk (vl-catch-all-apply 'vla-Item (list DocCol Dwg)))
           (if (vl-catch-all-error-p ErrChk)
               (if (and (= (getvar "sdi") 1) (/= (getvar "dbmod") 0))
                 (progn (initget "Y N")
                        (setq Opt
                               (getkword
                                 "\n Drawing has changed.  Save changes before exiting drawings? <Y> "))
                        (if (or (= Opt "Y") (not Opt))
                          (setq Opt "N")
                          (setq Opt "Y"))
                        (vl-cmdf
                          "_.vbastmt"
                          (strcat "AcadApplication.Documents.Open \"" DwgFile "\""))
                        (command Opt))
                 (vl-cmdf
                   "_.vbastmt"
                   (strcat "AcadApplication.Documents.Open \"" DwgFile "\""))))
             (command
               "_.vbastmt"
               (strcat "documents.item \(\"" (vla-get-Name ErrChk) "\"\).activate"))))
    ;;(alert "\n This is the last drawing in this folder.")
    (ARCH:ALERT-I
      "MsgBox \"
     Open Next Drawing Message
     You already are in the Last Drawing of this Directory!\"")
  (princ))
;;;by Tim Willey
(defun MyPrevious  (/ AcadObj DocCol DirPath DwgList Pos Dwg DwgFile ErrChk Opt)
    ; Opens/Makes-active previous drawing in the directory.
  (if (> Pos 0)
    (progn (setq Dwg (nth (1- Pos) DwgList))
                        (setq Opt
                               (getkword
                          (setq Opt "N")
                          (setq Opt "Y"))
                        (vl-cmdf
                          "_.vbastmt"
                        (command Opt))
                 (vl-cmdf
                   "_.vbastmt"
             (command
               "_.vbastmt"
    ;;(alert "\n This is the first drawing in this folder.")
    (ARCH:ALERT-I
      "MsgBox \"
     You already are in the First Drawing of this Directory!\"")
  (princ))
Re: Next and Previous dwg in directory
« Reply #1 on: March 18, 2008, 03:00:30 PM »
I have never had a problem with them Gary.  I will take a look when I get a moment, but then again I use '06 on a regular basis, so I might not see a problem.  I guess I might be able to run some tests on '08, as I do have it installed.  Let you know what I find out.
GDF
« Reply #2 on: March 18, 2008, 03:07:36 PM »
Thanks Tim. Like I said, it only happens once in a while...always when I'm in a rush.
Gary
« Reply #3 on: March 18, 2008, 03:49:06 PM »
What are you opening?  And what do you have open already?
I'm just trying to narrow it down a little, as maybe it's a memory issue with loading a lot of 3d objects, and xrefs.  I just opened about ~30 drawings, going next and previous, and didn't see anything happen.  Mine had some xrefs, but nothing 3d and nothing too intense.
GDF
« Reply #4 on: March 18, 2008, 04:22:44 PM »
Small to medium size unit plans...say eight files within a directory. 98% of the time the routine runs smoothly.
I checked outside and it is raining......nay that couldn't be it.
Sometimes I get this problem with Peter Jamtgaard's close drawings routine (a routine that closes all drawings selected within a dialog box).
This could be a netwok problem. Anyway thanks for checking it out for me. Others in our office have had the same problem with it locking up AutoCAD.
Like I said, I cannot work without this routine. Everyone here in the office uses it also.
Thanks again Tim.
« Reply #5 on: March 18, 2008, 05:16:00 PM »
I wonder if it is because it is using a VBA statement.  I'm not sure, but that would be my guess.  Maybe I'll see if I can do it in C#, so that the problem won't exist, and it will be a fun little project.  :-D
jbuzbee
« Reply #6 on: March 19, 2008, 10:58:35 AM »
Gary: What types of Reactors are you running?  There was a bug that got fixed - can't remember when - vlr-notification:
(vlr-notification myreactorObject 'active-document-only)
My command reactors caused havoc when opening / closing drawings until I set the above.
jb
James Buzbee
Windows 8
« Reply #7 on: March 19, 2008, 11:10:15 AM »
jb
Never knew about that one James.  Thanks.
« Reply #8 on: March 19, 2008, 12:55:18 PM »
Gary,
  Here is the C# code, and the dll file within the attached zip file.  I tested it in '08, and it seems to be working fine.  Let me know if you run into any problems.  The command names are the same once it's loaded, MyNext & MyPrevious.
  If you want them to auto load within Acad, you can see this post by Glenn that explains how to set that up.
 * Created by SharpDevelop.
 * User: Tim Willey
 * Date: 3/18/2008
 * Time: 4:17 PM
 * To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using System.IO;
using System.Collections;
using System.Windows.Forms;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass (typeof (Test.OpenNextPrevious))]
namespace Test
/// <summary>
/// Description of OpenNextPrevious.
/// </summary>
class MyStringCompare {
public MyStringCompare () {}
public static int Compare (object obj1, object obj2) {
string str1 = (string)obj1, str2 = (string)obj2;
int i1 = 0,
i2 = 0,
CompareResult,
l1 = str1.Length,
l2 = str2.Length,
tempI1,
tempI2;
string s1, s2;
bool b1, b2;
while (true) {
b1 = Char.IsDigit(str1, i1);
b2 = Char.IsDigit(str2, i2);
if ( !b1 && b2 )
return -1;
if ( b1 && !b2 )
return 1;
if (b1 && b2) {
FindLastDigit(str1, ref i1, out s1);
FindLastDigit(str2, ref i2, out s2);
tempI1 = Convert.ToInt32(s1);
tempI2 = Convert.ToInt32(s2);
if ( tempI1.Equals(tempI2) )
CompareResult = 0;
else if (tempI1 < tempI2)
CompareResult = -1;
else
CompareResult = 1;
if ( !CompareResult.Equals(0) )
return CompareResult;
else {
FindLastLetter(str1, ref i1, out s1);
FindLastLetter(str2, ref i2, out s2);
CompareResult = string.Compare(s1, s2);
if (l1 <= i1) {
if (l2 <= i2) {
return 0;
else {
return -1;
if (l2 <= i2) {
if (l1 < i1) {
return 0;
else {
return 1;
private static void FindLastLetter (string MainStr, ref int i, out string OutStr) {
int StartPos = i;
int StrLen = MainStr.Length;
++i;
while ( i < StrLen && !Char.IsDigit(MainStr, i) )
++i;
OutStr = MainStr.Substring(StartPos, i - StartPos);
private static void FindLastDigit (string MainStr, ref int i, out string OutStr) {
int StartPos = i;
++i;
while ( i < StrLen && Char.IsDigit(MainStr, i) )
++i;
public class OpenNextPrevious
[CommandMethod("MyNext", CommandFlags.Session)]
public void OpenNext()
OpenDrawing(1);
[CommandMethod("MyPrevious", CommandFlags.Session)]
public void OpenPrevious()
OpenDrawing(-1);
public void OpenDrawing (int ToOpen) {
Document Doc = null;
DocumentCollection DocCol = AcadApp.DocumentManager;
string DwgPath = AcadApp.GetSystemVariable("DwgPrefix") as string;
string DwgName = AcadApp.GetSystemVariable("DwgName") as string;
string FullPath = DwgPath + DwgName;
string[] DwgList = Directory.GetFiles(DwgPath, "*.dwg");
Array.Sort(DwgList, new MyStringCompare1());
int cNum = Array.IndexOf(DwgList, FullPath);
if ( ToOpen.Equals(1) ) {
if ( cNum.Equals(DwgList.Length - 1) ) {
MessageBox.Show("Already at the last drawing in the folder.", "Not really an error.");
return;
else {
if ( cNum.Equals(0) ) {
MessageBox.Show("Already at the first drawing in the folder.", "Not really an error.");
return;
string Path = DwgList[cNum + ToOpen];
foreach (Document doc in DocCol) {
if (string.Compare(Path, doc.Name, true).Equals(0)) {
Doc = doc;
break;
if (Doc != null)
DocCol.MdiActiveDocument = Doc;
else
DocCol.Open(Path, false);
public class MyStringCompare1 : IComparer {
public MyStringCompare1 () {}
public int Compare (object x, object y) {
return MyStringCompare.Compare( x,y );
GDF
« Reply #9 on: March 19, 2008, 02:54:25 PM »
James
Yes I have a lot of running reactors, will have to go thru them.
Thanks for the update.
Gary,
I think I'm over my head. Is the following below the reg file I need to make? I renamed your test.dll to NextPrev17.dll.
My command names would be "N2" for "MyNext" and "P2" for "MyPrevious".
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R17.1\ACAD-6001:409\Applications\NextPrev17]
"DESCRIPTION"="Next Previous Drawing in the Directory"
"LOADCTRLS"=dword:00000004
"LOADER"="V:\\ARCH\\Support\\V17\\NextPrev17.dll"
"MANAGED"=dword:00000001
[HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R17.1\ACAD-6001:409\Applications\NextPrev17\Commands]
"M2"="MyNext"
"P2"="MyPrevious"
Gary
« Reply #10 on: March 19, 2008, 03:18:40 PM »
That looks like what I have, except
"M2"="MyNext"
"P2"="MyPrevious"
Won't work.  I just tried it.  You have to have the values be the same on both sides (not sure why).  But once you do that you can change the pgp file to
M2, *MyNext
P2, *MyPrevious
and it will work.
GDF
« Reply #11 on: March 19, 2008, 03:46:19 PM »
Can't get it to work. The commands are unknown: "mynext" and "myprevious".
Gary
"LOADER"="V:\\ARCH\\Support\\V18\\NextPrev17.dll"
"MyNext"="MyNext"
"MyPrevious"="MyPrevious"
« Last Edit: March 19, 2008, 03:49:38 PM by Gary Fowler »
« Reply #12 on: March 19, 2008, 03:57:09 PM »
Try changing the LOADCTRLS to 12 instead of 4.  Mine is set to 12.  Not sure why I changed mine, so I didn't want to lead you astray earlier.
You may also have to add the Groups folder under the NextPrev17 folder.  Also you would add one string entry with both values being the same.  Mine are MyCommands, but I'm sure you can call it whatever you want.
GDF
« Reply #13 on: March 19, 2008, 04:12:28 PM »
Made the changes and still get unkown command.
[HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R17.1\ACAD-6001:409\Applications\NextPrev17\Groups]
"MYCommands"="MYCommands"
"LOADCTRLS"=dword:00000012
"MyNext"="MyNext"
Gary
« Last Edit: March 19, 2008, 04:33:14 PM by Gary Fowler »
« Reply #14 on: March 19, 2008, 04:50:37 PM »
Did you exit and reenter Acad?  Have you tried to just netload it and use the commands?
Are you using a netword path?  If so you might want to read the post after the one I linked to before.  .Net files act differently from local and network drives.
Here is what mine looks like.  I exported it to a text file.
Key Name:          HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R16.2\ACAD-4007:409\Applications\MyAcadCommands
Class Name:        <NO CLASS>
Last Write Time:   5/15/2007 - 3:26 PM
Value 0
  Type:            REG_SZ
  Data:            My dotNet applications.
Value 1
  Type:            REG_DWORD
  Data:            0xc
Value 2
  Type:            REG_DWORD
  Data:            0x1
Value 3
  Type:            REG_SZ
  Data:            C:\MyCustom\Dll\3MAutoCAD.dll
Key Name:          HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R16.2\ACAD-4007:409\Applications\MyAcadCommands\Commands
Last Write Time:   3/19/2008 - 12:11 PM
Value 0
  Type:            REG_SZ
  Data:            MyXrefManager
Value 1
  Type:            REG_SZ
  Data:            NewRev
Value 2
  Type:            REG_SZ
  Data:            MatchRevisions
Value 3
  Type:            REG_SZ
  Data:            UpdateRevCloud
Value 4
  Type:            REG_SZ
  Data:            MyBPlot
Value 5
  Type:            REG_SZ
  Data:            CopyXrefLayerProps
Value 6
  Type:            REG_SZ
  Data:            MyAttPalette
Value 7
  Type:            REG_SZ
  Data:            XrefCheck
Value 8
  Type:            REG_SZ
  Data:            NewUpdTitleBlock
Value 9
  Type:            REG_SZ
  Data:            FilterForEnglishWord
Value 10
  Type:            REG_SZ
  Data:            UpdateMiddleTitleLine
Key Name:          HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R16.2\ACAD-4007:409\Applications\MyAcadCommands\Groups
Value 0
  Type:            REG_SZ
  Data:            MyCommands
