Author Topic: Problem with spaces in script file  (Read 9025 times)
danglar
  • Read My Li(s)(p)
« on: December 03, 2015, 08:07:31 AM »
I have a program for add file prefix "Xref-" and suffix as current date
and open modified XREF file with close and delete previous file (see attached lisp).
Program working properly until you have file name with spaces between words
(example: pump station.dwg) or you have a path with spaces between words
(example: c:\Pump station\example.dwg)
Can somebody fix it?
Re: Problem with spaces in script file
« Reply #1 on: December 03, 2015, 08:36:36 AM »
Try putting quotes around the text like so "c:\Pump station\example.dwg"
danglar
  • Read My Li(s)(p)
« Reply #2 on: December 03, 2015, 08:40:40 AM »
Part and name of file here is a variable (not constant) so I need to do it programmaticaly somehow...
« Reply #3 on: December 03, 2015, 08:52:21 AM »
Use a combination of vl-prin1-to-string & strcat:
danglar
  • Read My Li(s)(p)
« Reply #4 on: December 03, 2015, 09:07:04 AM »
..but this string
  1. (alert (vl-prin1-to-string (strcat (getvar 'dwgprefix) "XREF-" (vl-filename-base (getvar 'dwgname) "-TPZ-" thedate ))))
  2.
  3.
returns an error: too many arguments
« Reply #5 on: December 03, 2015, 09:13:38 AM »
Your closing paren for vl-filename-base is in the wrong place.
danglar
  • Read My Li(s)(p)
« Reply #6 on: December 03, 2015, 09:27:07 AM »
right way is:
  1.
  2. (setq www (vl-prin1-to-string (strcat (getvar 'dwgprefix) "XREF-" (vl-filename-base (getvar 'dwgname)) "-TPZ-" thedate )))
  3.
  4.
but now i have an eror in this strings
  1. (write-line (strcat "open " www) fil1)
  2. (write-line (strcat "(vl-file-delete www)") fil1)
  3.
« Reply #7 on: December 03, 2015, 09:40:58 AM »
Sorry Danglar, I don't have time right now to debug your code. You initial question was just about spaces & text strings.
danglar
  • Read My Li(s)(p)
« Reply #8 on: December 03, 2015, 09:59:02 AM »
Thank you ronjonp. Your help was very appreciated..
« Reply #9 on: December 03, 2015, 10:20:39 AM »
You're welcome.
Prickle Farmer
  • 35+ years of AutoCAD / BricsCAD
« Reply #10 on: December 03, 2015, 07:58:23 PM »
Why make you life complicated with VL?
  1. (setq www (strcat (getvar "DWGPREFIX") "XREF-" (substr (getvar "DWGNAME") 1 (- (strlen (getvar "DWGNAME")) 4)) "-TPZ-" (rtos (gevar "CDATE") 2 0)))
EDIT: Added code tags. - John
« Last Edit: December 04, 2015, 02:00:38 PM by John Kaul (Se7en) »
I'd rather have a bottle in front of me than a frontal lobotomy.
« Reply #11 on: December 04, 2015, 10:23:53 AM »
What is complicated about VL ? Your solution seems more complicated to me.
danglar
  • Read My Li(s)(p)
« Reply #12 on: December 06, 2015, 01:19:18 AM »
Thank you
for your note, but I still have a problem with script ..
I have an error " error: no function definition: GEVAR"
when I invoke this string
  1. (write-line  "open " www fil1)
  2.
« Reply #13 on: December 06, 2015, 01:27:50 AM »
danglar
  • Read My Li(s)(p)
« Reply #14 on: December 06, 2015, 01:33:16 AM »
You are right:
correct string is:
  1. (setq www (strcat (getvar "DWGPREFIX") "XREF-" (substr (getvar "DWGNAME") 1 (- (strlen (getvar "DWGNAME")) 4)) "-TPZ-" (rtos (getvar "CDATE") 2 0)))
but program now not working properly
