I think you can use this to wait until the right button is released:
(while (= a 12)(setq a (car (grread T))))
Why does it work fine for me?
Please place (command "_.undo" "begin") before you change any variables.
You got it.
Rotating the UCS is an easy (but dirty) solution: then you must also set UCSFOLLOW to 0.
A better way is use the trans function to find the points of the bounding box and to draw the new objects.
Care to give an example?
Perhaps I was not using the bounding box function correctly,
BUT it returned the coordinated in UCS World of the objects but not at the
angle needed for the box.
Try rotating the text 45 deg, then rotate the UCS 90 deg and get a bounding box
that will wrap the text. I would be grateful for the solution.
Thanks.
