Having attributes with the same tag is a problem with both of our routines.
Additional programing is needed to specify which attribute needs to be changed else all matching attributes will be changed.
What problem are you experiencing with using 2 underscore characters?
To specify specify which is which.
You would need to specify first or last, or 1 or 2, etc.
