Author Topic: object to matrix  (Read 7234 times)
Coder
object to matrix
« on: June 09, 2014, 09:33:00 AM »
Hello guys .
Is there a way to get any object the matrix list ? for example when we use the nentselp function on some objects ?
(setq obj (nentselp))
will get something like this .
(<Entity name: 7efc75a0> (2447.52 783.137 0.0) ((1.0 0.0 0.0 2447.24) (0.0 1.0 0.0 783.079) (0.0 0.0 1.0 0.0) (0.0 0.0 0.0 1.0)) (<Entity name: 7efc7638>))
for example , how to get the matrix values with ssget or entsel function ?
(setq obj (car (entsel "\n Select object :")))
many thanks in advance .  :-)
« Last Edit: June 09, 2014, 09:44:29 AM by Coder »
reltro
Re: object to matrix
« Reply #1 on: June 09, 2014, 02:50:20 PM »
Hello guys .
Hey Coder...
I'm not sure how (nentselp) works or calculates the matrix...
When I read ur question the "Abritrary Axis Algorithm" come up in mind...
Its the way acad calculates the groupCode 210...
Im not sure if its the right way... Just have a look...
  1. ;;;-------------------------------------------------------------------------------------------
  2. ;;;                    ___...:::{Abritrary Axis Algorithm}:::...___
  3. ;;;
  4. ;;; http://www.autodesk.com/techpubs/autocad/acadr14/dxf/arbitrary_axis_algorithm_al_u05_c.htm
  5. (setq AAA
  6.         (lambda (P1 P2 P3 / cross Ax Ay Az)
  7.                 (setq cross
  8.                         (lambda (V1 V2 / )
  9.                                 (    (lambda (nV / o len)
  10.                                                 (setq len (sqrt (apply '+ (foreach k nV (setq o (cons (expt k 2) o))))))
  11.                                                 (mapcar '(lambda (a / ) (/ a len)) nV)
  12.                                         )
  13.                                         (mapcar
  14.                                                 '(lambda (n / ) (- (* (nth (car n) V1) (nth (cadr n) V2)) (* (nth (cadr n) V1) (nth (car n) V2))))
  15.                                                 '((1 2) (2 0) (0 1))
  16.                                         )
  17.                                 )
  18.                         )
  19.                 )
  20.                 (setq    Az    (cross (mapcar '- P1 P2) (mapcar '- P1 P3))
  21.                                 Ax    (if (and (< (abs (car Az)) (/ 1 64.0)) (< (abs (cadr Az)) (/ 1 64.0)))
  22.                                                 (cross '(0 1 0) Az)
  23.                                                 (cross '(0 0 1) Az)
  24.                                         )
  25.                                 Ay    (cross Az Ax)
  26.                 )
  27.                 (list Ax Ay Az)
  28.         )
  29. )
  30. ;;;-------------------------------------------------------------------------------------------
  31.
  32.
greets reltro
Coder
« Reply #2 on: June 09, 2014, 03:14:37 PM »
Thank you so much reltro for your help .
Can you please tell me how to call this function ?
Thank you  :-)
reltro
« Reply #3 on: June 09, 2014, 04:10:29 PM »
Thank you  :-)
I don't tought it would be usefull...
(AAA (getpoint) (getpoint) (getpoint)
roy_043
  • BricsCAD 18
« Reply #4 on: June 09, 2014, 06:56:58 PM »
Let's not forget the (trans) function...
Coder
« Reply #5 on: June 10, 2014, 01:04:02 AM »
Thank you  :-)
Thank you reltro for your help .
But i need to run the function on entity name and not through getting points .  :oops:
Can you please modify the code ?
Many many thanks .
Coder
« Reply #6 on: June 10, 2014, 01:06:44 AM »
Hi roy .
Can you give me example if you have time to ?
Many thanks  :-)
gile
  • Marseille, France
« Reply #7 on: June 10, 2014, 01:53:24 AM »
I think you'd rather explain what you want to achieve, because it looks like you're going a wrong route.
Only block reference have such transformation matrices.
When you run nentsel(p) on an entity, you'll get this kind of matrix only in case the entity is a block component. The matrix reflects the block reference transformations.
Coder
« Reply #8 on: June 10, 2014, 02:20:33 AM »
Thank you gile for your kind reply .
yes I want to get the matrix for Circle or LWpolyline in block to be able to create a copy of it and transfer it to current space ( model ) .
  (if (setq sel (ssget "_:L" '((0 . "INSERT"))))
    (repeat (setq num (sslength sel))
      (setq ent (ssname sel (setq num (1- num))))
      (setq tbl-obj (tblobjname "BLOCK" (cdr (assoc 2 (entget ent)))))
      (while (setq tbl-obj (entnext tbl-obj))
        (if (or (equal (cdr (assoc 0 (entget tbl-obj))) "CIRCLE")
                (equal (cdr (assoc 0 (entget tbl-obj))) "LWPOLYLINE")
            (setq mat (.....)) ;; <<<<<<<<<<<<<<<<<<<<
            (setq obj (entmakex (entget (car ent))))
            (vla-transformby (vlax-ename->vla-object obj) (vlax-tmatrix (caddr mat)))
reltro
« Reply #9 on: June 10, 2014, 03:46:27 AM »
Hey Coder...
Try this, calculates the Matrix for a BlockRef... I did not tested it carefully but in this tests I did it calculates the same transformation-matrix as nentselp...
  1. (defun TMatrix (BlockRef / TransformationMatrix BlockRef)
  2.     ;;;    ****
  3.     ;;;    Author:    Reltro
  4.     ;;;    ****
  5.     (setq TransformationMatrix
  6.         (lambda (P1 P2 P3 / AAA tMatrix Rotation mxm)
  7.             ;;;-------------------------------------------------------------------------------------------
  8.             ;;;                    ___...:::{Abritrary Axis Algorithm}:::...___
  9.             ;;;
  10.             ;;; http://www.autodesk.com/techpubs/autocad/acadr14/dxf/arbitrary_axis_algorithm_al_u05_c.htm
  11.             (setq AAA
  12.                 (lambda (P1 P2 P3 / cross Ax Ay Az)
  13.                     (setq cross
  14.                         (lambda (V1 V2 / )
  15.                             (    (lambda (nV / o len)
  16.                                     (setq len (sqrt (apply '+ (foreach k nV (setq o (cons (expt k 2) o))))))
  17.                                     (mapcar '(lambda (a / ) (/ a len)) nV)
  18.                                 )
  19.                                 (mapcar
  20.                                     '(lambda (n / ) (- (* (nth (car n) V1) (nth (cadr n) V2)) (* (nth (cadr n) V1) (nth (car n) V2))))
  21.                                     '((1 2) (2 0) (0 1))
  22.                                 )
  23.                             )
  24.                         )
  25.                     )
  26.                     (setq    Az    (cross (mapcar '- P1 P2) (mapcar '- P1 P3))
  27.                             Ax    (if (and (< (abs (car Az)) (/ 1 64.0)) (< (abs (cadr Az)) (/ 1 64.0)))
  28.                                     (cross '(0 1 0) Az)
  29.                                     (cross '(0 0 1) Az)
  30.                                 )
  31.                             Ay    (cross Az Ax)
  32.                     )
  33.                     (list Ax Ay Az)
  34.                 )
  35.             )
  36.             ;;;-------------------------------------------------------------------------------------------
  37.
  38.
  39.             ;;;-------------------------------------------------------------------------------------------
  40.             (setq   mxm         (lambda (m v) (mapcar '(lambda (r) (apply '+ (mapcar '* r v))) m))
  41.                     Rotation    (lambda (V ang / m+m mxs vxs)
  42.                                     ;;; >>>>>>>>>
  43.                                     ;;; Lee Mac
  44.                                     ;;; http://www.lee-mac.com/matrixtransformationfunctions.html
  45.                                     (setq m+m   (lambda (m n) (mapcar '(lambda (r s) (mapcar '+ r s)) m n))
  46.                                              mxs    (lambda (m s) (mapcar '(lambda (r) (mapcar '(lambda (n) (* n s)) r)) m))
  47.                                              vxs     (lambda (v s) (mapcar '(lambda (n) (* n s)) v))
  48.                                     )
  49.
  50.                                     (m+m
  51.                                         (list
  52.                                             (list (cos ang) 0. 0.)
  53.                                             (list 0. (cos ang) 0.)
  54.                                             (list 0. 0. (cos ang))
  55.                                         )
  56.                                         (m+m
  57.                                             (mxs
  58.                                                 (list
  59.                                                     (list 0. (- (nth 2 V)) (nth 1 V))
  60.                                                     (list (nth 2 V) 0. (- (nth 0 V)))
  61.                                                     (list (- (nth 1 V)) (nth 0 V) 0.)
  62.                                                 )
  63.                                                 (sin ang)
  64.                                             )
  65.                                             (mxs (mapcar '(lambda (e) (vxs V e)) V) (- 1. (cos ang)))
  66.                                         )
  67.                                     )
  68.                                     ;;; <<<<<<<<<
  69.                                 )
  70.             )
  71.             ;;;-------------------------------------------------------------------------------------------
  72.             (setq tMatrix (AAA P1 P2 P3))
  73.
  74.             (append
  75.                 (mapcar
  76.                     '(lambda (v o / ) (append (mxm tMatrix v) (list o)))
  77.                     (Rotation
  78.                         (nth 2 tMatrix)
  79.                         (angle (mxm tMatrix P1) (mxm tMatrix P2))
  80.                     )
  81.                     P1
  82.                 )
  83.                 (list '(0 0 0 1))
  84.             )
  85.         )
  86.     )
  87.
  88.     (defun BCS2WCS (BlockRef pointlist / ent inspkt ang)
  89.         (setq ent (entget BlockRef))
  90.         (setq inspkt (cdr (assoc 10 ent)))
  91.         (setq ang (cdr (assoc 50 ent)))
  92.         (mapcar
  93.             '(lambda (Pt /)
  94.                 (trans
  95.                     (mapcar
  96.                         '+
  97.                         (polar
  98.                             '(0 0 0)
  99.                             (+ ang (angle '(0 0 0) Pt))
  100.                             (distance '(0 0 0) Pt)
  101.                         )
  102.                         inspkt
  103.                     )
  104.                     BlockRef
  105.                     0
  106.                 )
  107.             )
  108.             pointlist
  109.         )
  110.     )
  111.
  112.     (apply
  113.         '(lambda (P1 P2 P3 / )
  114.             (TransformationMatrix P1 P2 P3)
  115.         )
  116.         (BCS2WCS BlockRef '((0 0 0) (1 0 0) (1 1 0)))
  117.     )
  118. )
  1. (TMatrix (car (entsel))) ;Select a BlockReferene
reltro
gile
  • Marseille, France
« Reply #10 on: June 10, 2014, 04:20:59 AM »
here's a way:
  1. ;; gc:EnameMatrix (gile)
  2. ;; Returns the transformation matrix of a block reference,
  3. ;; the same as the one returnd by (caddr (nentselp)).
  4. ;;
  5. ;; Argument
  6. ;; ename : entity name of the block reference
  7. (defun gc:EnameMatrix (ename / trp mxv mxm elst ang norm mat)
  8.
  9.   ;; TRP
  10. ;; Transpose a matrix -Doug Wilson-
  11. (defun trp (m) (apply 'mapcar (cons 'list m)))
  12.
  13. ;; MXV
  14. ;; Apply a transformation matrix to a vector -Vladimir Nesterovsky-
  15. (defun mxv (m v)
  16.   (mapcar (function (lambda (r) (apply '+ (mapcar '* r v)))) m)
  17. )
  18.
  19. ;; MXM
  20. ;; Multiply two matrices -Vladimir Nesterovsky-
  21. (defun mxm (m q)
  22.   (mapcar (function (lambda (r) (mxv (trp q) r))) m)
  23. )
  24.
  25.   ;; Main
  26.   (setq elst (entget ename)
  27.         ang  (cdr (assoc 50 elst))
  28.         norm (cdr (assoc 210 elst))
  29.   )
  30.   (append
  31.     (mapcar
  32.       (function
  33.         (lambda (v1 v2)
  34.           (append v1 (list v2))
  35.         )
  36.       )
  37.       (setq mat
  38.              (mxm
  39.                (mapcar (function (lambda (v) (trans v 0 norm T)))
  40.                        '((1. 0. 0.) (0. 1. 0.) (0. 0. 1.))
  41.                )
  42.                (mxm
  43.                  (list (list (cos ang) (- (sin ang)) 0.)
  44.                        (list (sin ang) (cos ang) 0.)
  45.                        '(0. 0. 1.)
  46.                  )
  47.                  (list (list (cdr (assoc 41 elst)) 0. 0.)
  48.                        (list 0. (cdr (assoc 42 elst)) 0.)
  49.                        (list 0. 0. (cdr (assoc 43 elst)))
  50.                  )
  51.                )
  52.              )
  53.       )
  54.       (mapcar
  55.         '-
  56.         (trans (cdr (assoc 10 elst)) norm 0)
  57.         (mxv mat
  58.              (cdr (assoc 10 (tblsearch "BLOCK" (cdr (assoc 2 elst)))))
  59.         )
  60.       )
  61.     )
  62.     '((0. 0. 0. 1.))
  63.   )
  64. )
<EDIT: see reply #12>
About your code, using entmake to copy the entity, adds the copy to the same owner (here, the block definition). To copy objects form an owner to another (here, the model space), you have to use vla-CopyObjects.
You'd have to take care the block reference is uniformly scaled, if not, vla-TransformBy will raise an error.
Test command:
  1. (defun c:test (/ butlast uniformp ms sel num ent mat ent lst)
  2.   (or *acad* (setq *acad* (vlax-get-acad-object)))
  3.   (or *acdoc* (setq *acdoc* (vla-get-ActiveDocument *acad*)))
  4.   (or *blocks* (setq *blocks* (vla-get-Blocks *acdoc*)))
  5.
  6.   ;; butlast
  7.   ;; Return the list but last item
  8.   (defun butlast (l) (reverse (cdr (reverse l))))
  9.
  10.   ;; uniformp
  11.   ;; Evaluate if a 4x4 transformation matrix is uniformly scaled
  12.   (defun uniformp (m)
  13.     (setq m (butlast (mapcar 'butlast m)))
  14.     (vl-every
  15.       (function
  16.         (lambda (v)
  17.           (equal (distance '(0. 0. 0.) (car m))
  18.                  (distance '(0. 0. 0.) v)
  19.                  1e-12
  20.           )
  21.         )
  22.       )
  23.       m
  24.     )
  25.   )
  26.
  27.   ;; Main
  28.   (setq ms (vla-get-ModelSpace *acdoc*))
  29.   (if (setq sel (ssget "_:L" '((0 . "INSERT"))))
  30.     (repeat (setq num (sslength sel))
  31.       (setq mat (gc:EnameMatrix (setq ent (ssname sel (setq num (1- num))))))
  32.       (if (uniformp mat)
  33.         (progn
  34.           (setq lst nil)
  35.           (vlax-for o (vla-Item *blocks* (cdr (assoc 2 (entget ent))))
  36.             (if (wcmatch (vla-get-ObjectName o) "AcDbCircle,AcDbPolyline")
  37.               (setq lst (cons o lst))
  38.             )
  39.           )
  40.           (foreach o (vlax-invoke *acdoc* 'CopyObjects lst ms)
  41.             (vla-transformby o (vlax-tmatrix mat))
  42.           )
  43.         )
  44.       )
  45.     )
  46.   )
  47.   (princ)
  48. )
« Last Edit: June 10, 2014, 05:16:27 AM by gile »
roy_043
  • BricsCAD 18
« Reply #11 on: June 10, 2014, 04:55:41 AM »
My attempt (not as sophisticated as gile's code):
; Get a 4X4 nentselp or 'tmatrix' from an insert.
(defun c:test1 ( / ang elist ename scaleX scaleY scaleZ)
  (setq ename (car (entsel))) ; Ename of insert.
  (setq elist (entget ename))
  (setq ang (cdr (assoc 50 elist)))
  (setq scaleX (cdr (assoc 41 elist)))
  (setq scaleY (cdr (assoc 42 elist)))
  (setq scaleZ (cdr (assoc 43 elist)))
  (KGA_Geom_MatrixMake
    (mapcar '* (trans (list (cos ang) (sin ang) 0.0) ename 0 T)     (list scaleX scaleX scaleX)) ; XVector.
    (mapcar '* (trans (list (- (sin ang)) (cos ang) 0.0) ename 0 T) (list scaleY scaleY scaleY)) ; YVector.
    (mapcar '* (trans '(0.0 0.0 1.0) ename 0 T)                     (list scaleZ scaleZ scaleZ)) ; ZVector.
    (vlax-get (vlax-ename->vla-object ename) 'insertionpoint)
; Get a nentsel matrix from an insert.
(defun c:test2 ( / ang elist ename scaleX scaleY scaleZ)
  (list
;;; Lib function: KGA_Geom_MatrixMake (20120201)
;;; Purpose:      Get a matrix from three vectors and an origin.
;;; Arguments:    xVector - x vector
;;;               yVector - y vector
;;;               zVector - z vector
;;;               origin  - origin
;;; Return value: A matrix. See Matrix Theory.
;;; Examples:     None
(defun KGA_Geom_MatrixMake (xVector yVector zVector origin / lst)
  (setq lst (list xVector yVector zVector origin))
  (append
    (mapcar
      '(lambda (a) (mapcar a lst))
      '(car cadr caddr)
    '((0.0 0.0 0.0 1.0))
;;; Matrix theory:
;;; A 4X4 matrix represents a coordinate system:
;;;   (Xx  Yx  Zx  Ox )
;;;   (Xy  Yy  Zy  Oy )
;;;   (Xz  Yz  Zz  Oz )
;;;   (0.0 0.0 0.0 1.0) ; this row is not used!
;;; X = X-axis vector
;;;       Xx = x-component of X-axis vector
;;;       Xy = y-component of X-axis vector
;;;       Xz = z-component of X-axis vector
;;; Y = Y-axis vector
;;;       idem
;;; Z = Z-axis vector
;;;       idem
;;; O = origin
;;;       idem
;;; The vectors don't have to be unit vectors. For instance in a matrix
;;; produced by using nentselp on an entity in an insert, they will
;;; reflect the block's scaling.
;;; Note:
;;; Whereas nentselp uses this standard matrix type, nentsel uses this
;;; matrix type instead:
;;;   (Xx  Xy  Xz)
;;;   (Yx  Yy  Yz)
;;;   (Zx  Zy  Zz)
;;;   (Ox  Oy  Oz)
roy_043
  • BricsCAD 18
« Reply #12 on: June 10, 2014, 05:00:55 AM »
This is not correct. The entity is added to the active space.
gile
  • Marseille, France
« Reply #13 on: June 10, 2014, 05:18:21 AM »
Thanks roy_043.
I misinterpreted an error during my tests.
Coder
« Reply #14 on: June 10, 2014, 07:12:37 AM »
reltro
Thank you so much reltro for your help  :-)
Your codes after selecting a block give a list of matrix values , does that mean we can use these values with any entity name in the same block  to transfer to model space for example ?
gile
Your codes is fantastic and the same I wanted , many many thanks to you .  :-)
roy_043
I tried your codes but nothing happened , maybe I missed something or did not use it should be . sorry  :oops:
Many thanks to you for your help .
reltro
« Reply #15 on: June 10, 2014, 07:34:25 AM »
reltro
Should work...
The function returns a transformationMatrix wich transforms objects from the origin of the WCS to the CoordinateSystem of the BlockReference...
if u (entget ...) an object wich is inside the BlockReference u get the Coordinates realtive to it, then (entmake ...) it in the ModelSpace (is an other Block) an transform it with the matrix
(defun C:Test (/ sel num ent tbl-obj mat)
            (setq mat (vlax-tmatrix (TMatrix ent)))
                 (vla-transformby (vlax-ename->vla-object (entmakex (entget tbl-obj))) mat)
Take care and test it well! not sure it works on any BlockReferences, but should do ;)
reltro
Coder
« Reply #16 on: June 10, 2014, 07:40:55 AM »
reltro
Should work...
reltro
Fantastic  work :-D
It copies every object to current space but I think I can take care of filtering the required object that I want .
Many many thanks for your time and nice work .
reltro
« Reply #17 on: June 10, 2014, 07:45:50 AM »
reltro
It was the question  8-) and I had to test it ;)
but u gave urself allready the code do filter some out...
reltro
roy_043
  • BricsCAD 18
« Reply #18 on: June 10, 2014, 09:23:33 AM »
roy_043
My functions only return a matrix.
Coder
« Reply #19 on: June 10, 2014, 11:14:37 AM »
I got it , thank you so much .  :-)
reltro
« Reply #20 on: June 10, 2014, 11:57:16 AM »
roy_043
Hey roy_043
I think ur matrix is only valid if the GroupCode 210 of the BlockRef is '(210 0.0 0.0 1.0) or am I wrong?
roy_043
  • BricsCAD 18
« Reply #21 on: June 11, 2014, 04:42:12 AM »
roy_043
Hey roy_043
You are wrong but my code may fail in certain cases so I am interested in your testing.
Attached is a test dwg. My test:
: (setq myMatrix (c:test1))
Select entity: ((0.346423 -0.533448 0.771637 23.0678) (0.938078 0.196997 -0.284958 -8.5187) (-2.01472e-016 0.822572 0.568661 17.1853) (0.0 0.0 0.0 1.0))
: (equal myMatrix (caddr (nentselp)) 1e-8)
Select entity: T
roy_043
  • BricsCAD 18
« Reply #22 on: June 13, 2014, 09:33:40 AM »
The code in one of my previous posts actually does have an issue. It does not take the base point of the block definition into account. Gile's code does.
My improved and cleaned up code:
;;; 20140613
;;; Get a matrix from an insert.
;;; See: http://www.theswamp.org/index.php?topic=47227.0
;;; (equal (KGA_Geom_MatrixMakeInsert (car (entsel))) (caddr (nentselp)) 1e-8)
(defun KGA_Geom_MatrixMakeInsert (ename / ang elist normal xVector yVector zVector)
  (setq normal (cdr (assoc 210 elist)))
    (setq xVector (KGA_Geom_VectorScale (trans (list (cos ang) (sin ang) 0.0) normal 0 T)     (cdr (assoc 41 elist))))
    (setq yVector (KGA_Geom_VectorScale (trans (list (- (sin ang)) (cos ang) 0.0) normal 0 T) (cdr (assoc 42 elist))))
    (setq zVector (KGA_Geom_VectorScale (trans '(0.0 0.0 1.0) normal 0 T)                     (cdr (assoc 43 elist))))
    (mapcar
      (trans (cdr (assoc 10 elist)) normal 0) ; Origin (insertion point).
      (mapcar
        '(lambda (lst) (apply '+ lst))
        (KGA_Geom_MatrixTranspose
          (mapcar
            'KGA_Geom_VectorScale
            (list xVector yVector zVector)
            (cdr (assoc 10 (tblsearch "block" (cdr (assoc 2 elist))))) ; Base point of the block definition.
;;; 20140613: Revised. See (KGA_Geom_MatrixTranspose).
;;; 20120201
;;; Get a 4x4 matrix from three vectors and an origin.
(defun KGA_Geom_MatrixMake (xVector yVector zVector origin)
  (append
    (mapcar 'list xVector yVector zVector origin)
;;; 20140613
;;; Transpose a matrix.
;;; By Doug Wilson (via gile, www.theswamp.org). Original name 'trp'.
(defun KGA_Geom_MatrixTranspose (matrix)
  (apply 'mapcar (cons 'list matrix))
; 20120201
; (KGA_Geom_VectorScale '(1 2 3) 3) => (3.0 6.0 9.0)
(defun KGA_Geom_VectorScale (vector scalar)
  (mapcar '(lambda (a) (* a (float scalar))) vector)
