reltro
Thank you so much reltro for your help
Your codes after selecting a block give a list of matrix values , does that mean we can use these values with any entity name in the same block to transfer to model space for example ?
gile
Your codes is fantastic and the same I wanted , many many thanks to you .
roy_043
I tried your codes but nothing happened , maybe I missed something or did not use it should be . sorry
Many thanks to you for your help .
