Author Topic: selection set "by length"  (Read 7196 times)
« Reply #15 on: February 08, 2005, 02:03:58 PM »
My pleasure Mark. :wink:
« Reply #16 on: February 09, 2005, 10:10:02 PM »
Speaking of optimizing, benchmarking ... thought you might find this illuminating Mark ...
Using this benchmarking utility ...
(defun c:Test
        GetEnameDistance
        GetEnameLength
        GetObjectLength
        ename
        object
    (defun GetEnameDistance ( ename / data )
        (distance
            (cdr (assoc 10 (setq data (entget ename))))
            (cdr (assoc 11 data))
    (defun GetEnameLength ( ename )
        (vlax-get-property
            (vlax-ename->vla-object ename)
            'Length
    (defun GetObjectLength ( object )
        (vlax-get-property
            object
            'Length
    (setvar "cmdecho" 0)
    (command ".line" '(0 0) '(10 10) "")
    (setq object
            (setq ename (entlast))
    (Benchmark
            (GetEnameDistance ename)
            (GetEnameLength ename)
            (GetObjectLength object)
    (vl-catch-all-apply
       '(lambda ()
            (entdel ename)
(c:Test)
Output:
Elapsed milliseconds / relative speed for 32768 iteration(s):
    (GETOBJECTLENGTH OBJECT).....1687 / 1.63 <fastest>
    (GETENAMEDISTANCE ENAME).....1985 / 1.39
    (GETENAMELENGTH ENAME).......2750 / 1.00 <slowest>
« Reply #17 on: February 10, 2005, 08:08:55 AM »
Now that is cool !!
I'm surprised that 'GetEnameDistance' was slower than 'GetObjectLength'.
SMadsen
« Reply #18 on: February 10, 2005, 08:30:33 AM »
Got another result:
   (GETENAMEDISTANCE ENAME).....1234 / 1.82 <fastest>
    (GETOBJECTLENGTH OBJECT).....1390 / 1.62
    (GETENAMELENGTH ENAME).......2250 / 1.00 <slowest>
SMadsen
« Reply #19 on: February 10, 2005, 08:41:47 AM »
Here's an interesting observation. Given the function below, passing an object to it is slower than passing an ename:
   (defun GetCurveLength ( object )
      (vlax-curve-getDistAtPoint
        object
        (vlax-curve-getEndPoint object)
Object:
    (GETENAMEDISTANCE ENAME).....1219 / 1.99 <fastest>
    (GETOBJECTLENGTH OBJECT).....1484 / 1.63
    (GETCURVELENGTH OBJECT)......2047 / 1.18
    (GETENAMELENGTH ENAME).......2422 / 1 <slowest>
Ename:
    (GETCURVELENGTH ENAME).......1235 / 2.19 <fastest>
    (GETENAMEDISTANCE ENAME).....1500 / 1.8
    (GETOBJECTLENGTH OBJECT).....1781 / 1.52
    (GETENAMELENGTH ENAME).......2703 / 1 <slowest>
« Reply #20 on: February 10, 2005, 08:48:44 AM »
My results. Ran it twice.
   (GETENAMEDISTANCE ENAME).....1222 / 1.57 <fastest>
    (GETOBJECTLENGTH OBJECT).....1322 / 1.45
    (GETENAMELENGTH ENAME).......1913 / 1.00 <slowest>
    (GETENAMEDISTANCE ENAME).....1112 / 1.65 <fastest>
    (GETOBJECTLENGTH OBJECT).....1271 / 1.44
    (GETENAMELENGTH ENAME).......1833 / 1.00 <slowest>
PS.  I think Michael's computer has a vla bias. :)
« Reply #21 on: February 10, 2005, 09:32:21 AM »
my results.
:: pasted 'test' strait into acad
    (GETOBJECTLENGTH OBJECT).....1375 / 1.66 <fastest>
    (GETENAMEDISTANCE ENAME).....1766 / 1.29
    (GETENAMELENGTH ENAME).......2281 / 1.00 <slowest>
:: from within the vlide/vlisp console
Benchmarking .................Elapsed milliseconds / relative speed for 16384 iteration(s):
    (GETENAMEDISTANCE ENAME).....1062 / 1.97 <fastest>
    (GETOBJECTLENGTH OBJECT).....1281 / 1.63
    (GETENAMELENGTH ENAME).......2094 / 1.00 <slowest>
« Reply #22 on: February 10, 2005, 10:49:35 AM »
Quick note --
I was running under AutoCAD 2004 and killed all other apps as well as my internet connection.
Also --
Quote from: Disclaimer
   ;;  Notes:
    ;;      I make no claims that this is definitive benchmarking. I
    ;;      wrote this utility for my own purposes and thought I'd
    ;;      share it. Many considerations go into evaluating the
    ;;      performance or suitability of an algorythm for a given
    ;;      task. Raw performance as profiled herein is just one.
    ;;      Please note that background dramatically affect results.
In other words, it's a guide, an indicator of performance, but as written I don't think it's a definitive work for benchmarking. Take the results with a grain a salt, switch the order of the statements being evaluated, perform several runs etc.
<gotto go, sorry to be so brief>
