Author Topic: Late binding AxDbDocument  (Read 2999 times)
Bryco
« on: February 13, 2007, 11:23:56 PM »
I've finally had a little time to play with 2007 and once again there is reference problems.
The function below seems to work ok but I presume I'm going to get a perfermance hit.
Although I've written functions to set the correct reference before, I've never made a reliable one.
Does anyone have an early binding solution that works for 2006 and 2007?
Function SetAxdb() As Object
    'Dim dbxDoc As New AxDbDocument
    Dim dbxDoc As Object
    Select Case AcadVer
        Case 2000
            Set dbxDoc = GetInterfaceObject("ObjectDBX.AxDbDocument")
        Case 2002, 2004, 2005, 2006
            Set dbxDoc = GetInterfaceObject("ObjectDBX.AxDbDocument.16")
        Case 2007
            Set dbxDoc = GetInterfaceObject("ObjectDBX.AxDbDocument.17")
    End Select
    Set SetAxdb = dbxDoc
End Function
Fatty
Re: Late binding AxDbDocument
« Reply #1 on: February 14, 2007, 05:09:24 AM »
Hello, Bryco  :-)
I do not use late binding
here is a trick I use
Define ObjectDBX twice
     Dim oDBX As AxDbDocument
     Set oDBX = New AxDbDocument
     Set oDBX = Application.GetInterfaceObject("ObjectDBX.AxDbDocument.16")     '<--17 for A2006 and higher
I have A2005 only on my machine though
Hope that helps
~'J'~
