Author Topic: Xref Tools  (Read 12006 times)
Glenn R
Re: Xref Tools
« Reply #15 on: July 12, 2008, 03:45:42 PM »
BTW, nice delegation there Chuck :)
Spike Wilbury
Re: Xref Tools
« Reply #16 on: July 12, 2008, 06:32:37 PM »
Chuck is the man.... I learn a lot from him, in my early C++ and ObjectARX digesting days - from you too Glenn, the man2.  :)
Chuck Gabriel
Re: Xref Tools
« Reply #17 on: July 12, 2008, 08:18:31 PM »
Thanks for the kind words guys.
Glenn R
Re: Xref Tools
« Reply #18 on: July 13, 2008, 04:26:27 AM »
Hey Luis, good to see you again.
autocart
Re: Xref Tools
« Reply #19 on: August 03, 2011, 03:04:31 AM »
Hi, I hope nobody minds the push since it relates directly (so in case someone ever has the same problem it is handled right here).
I cant get the code to work. I use Autocad 2011 with VS 2010 EE and the "AutoCAD 2011 .Net Wizards" from the Developer Center. All that on Win7 64 bit. Everything in German.
Debug starts fine, Autocad starts up. I can netload without problems.
But now, when I type attachxrefs, Autocad seems to do nothing and hangs. Nothing happens anymore. The only thing I can do is to end the debugging.
Or, when I type bindxrefs, then I get asked "Select xrefs to bind: " but as soon as I move the mouse or press a button I get an Autocad-error-message saying "SYSTEM ERROR: Unsupported version of Windows Presentation Foundation".
Does anybody have an idea? Thx.
EDIT:
Sorry for the bother. I found the solution: The compiled dll may not be located on a network drive but must be local.
See also:
http://blog.jtbworld.com/2009/03/fatal-error-unsupported-version-of.html
and
http://www.cadtutor.net/forum/showthread.php?51395-VB.Net&s=5ef6ab1938a8d29d4590a757b34afe71
« Last Edit: August 03, 2011, 03:39:48 AM by autocart »
airportman
  • i customize when required
Re: Xref Tools
« Reply #20 on: March 04, 2013, 06:44:41 PM »
Autocart:
I too had this same issue with another DLL that I was able make work on my laptop, but never on my desktop. Turns out, the dll had to be local.
cheers,
Perception is a state of mind  -/ Twitter = @hochanz -/ Intel i7 - 3.07GHz -/ 12GB Ram -/ Nvidia Quadro FX 1800
