Author Topic: Find 2 nearest intersection point from text insertion  (Read 3001 times)
m4rdy
« on: April 25, 2011, 04:17:44 AM »
How do we find two nearest intersection point from text insertion point?
Thank you.
m4rdy
Autocad 2007, Windows XP
Re: Find 2 nearest intersection point from text insertion
« Reply #1 on: April 25, 2011, 05:54:06 AM »
  • Make a SelectionSet of all candidate lines
  • Find all points of intersection between all objects within such a SelectionSet (example here)
  • Sort the list of intersection points by distance to a certain point.
« Reply #2 on: April 25, 2011, 08:48:07 AM »
Not covered by the spec' ..
will the text always be parallel with the concrete beam centerLine ( I assume you are endeavouring to extract the beam length)
I can see some problems with just accepting the closest points to the text.
Perhaps determine the closest centerline then find the intersection of intersecting candidates ... etc
m4rdy
« Reply #3 on: April 25, 2011, 09:10:15 AM »
Hi Kerry
Yes, the text always be parallel with the concrete beam centerline.
And Yes, i need to make polylines from those 2 points and the end result is finding the beam length.
Yes again, that's my problem.
So far, this is my pseudo code:
1. Get all insertion point of texts in "BEAM" layer
2. Get all intersection points of line in "GRID" layer
3. Find the nearest GRID line from each of insertion text
4. Find 2 nearest intersection point from result no.3
5. Make polyline from result no.4
I hope that makes more clearly (or not... :-()
Thank you Lee Mac and Kerry.
m4rdy
« Reply #4 on: April 25, 2011, 09:34:42 AM »
Draft of my pseudo code - as Kerry states though, this method is not bullet-proof.
(defun c:test ( / pt ss in ) (vl-load-com)
    (and
      (setq pt (getpoint "\nPoint to Test: "))
      (setq ss (ssget "_X" '((0 . "LINE") (8 . "GRID"))))
      (setq in (LM:GetIntersectionsinSS ss))
      (< 1 (length in))
      (setq pt (trans pt 1 0)
            in (vl-sort in '(lambda ( a b ) (< (distance a pt) (distance b pt))))
      (foreach x (list (car in) (cadr in))
        (entmakex (list (cons 0 "POINT") (cons 10 x)))
m4rdy
« Reply #5 on: April 25, 2011, 09:59:14 AM »
Wow, so fast reply.
Thank you Lee.
Much appreciated.
m4rdy
« Reply #6 on: April 25, 2011, 11:22:05 AM »
So what are you doing with the text you collect?
m4rdy
« Reply #7 on: April 25, 2011, 11:32:51 AM »
Hi Alan,
For finding insertion point of each text as base point to find two nearest intersection points.
m4rdy
m4rdy
« Reply #8 on: April 25, 2011, 11:40:13 AM »
;; Entmake lwpolyline
(defun LWPoly (lst cls)
  (entmakex
    (append (list (cons 0 "LWPOLYLINE")
 (cons 100 "AcDbEntity")
 (cons 100 "AcDbPolyline")
 (cons 90 (length lst))
 (cons 70 cls);_0 = open 1 = closed
 (cons 40 10.)
 (cons 41 10.)
   (mapcar (function (lambda (p) (cons 10 (trans p 0 1)))) lst)
;; Get insertion point of text
;; Return : ((ename1 (ins_point1)) (ename2 (ins_point2))...)
(defun get-ins-txt (sset / i j ent sset entl ins_point)
  (setq i -1)
  (while (setq ent (ssname sset (setq i (1+ i))))
    (setq entl (entget ent)
 ins_point (cons (cons ent (list (cdr (assoc 10 entl))))  ins_point)
;; Original from Lee mac
;; modified by m4rdy
(defun c:beam (/ pt ss1 ss2 in ins_txt)
  (princ "SELECT BEAM TEXT")
  (setq ss1 (ssget "_X" '((0 . "LINE") (8 . "GRID"))))
  (setq ss2 (ssget '((0 . "TEXT") (8 . "BEAM"))))
  (setq in (LM:GetIntersectionsinSS ss1))
  (setq ins_txt (get-ins-txt ss2))
  (if (and ss1 ss2 (< 1 (length in)))
      (foreach x ins_txt
(setq pt (trans (cadar ins_txt) 1 0)
     in (vl-sort in
 '(lambda (a b) (< (distance a pt) (distance b pt)))
(LWPoly (list (car in) (cadr in)) 0)
      ) ;_foreach
    ) ;_progn
  ) ;_if
I have some troubles with 'foreach'.
If anybody can help..
Thank you
m4rdy
« Last Edit: April 25, 2011, 11:44:15 AM by m4rdy »
« Reply #9 on: April 25, 2011, 11:49:19 AM »
Hi M4rdy,
Perhaps try something like this:
  (entmakex
  (cons 40 10.)
  (cons 41 10.)
(defun LM:GetTextInsertion ( eList )
  (cdr
    (assoc
        (and
          (zerop (cdr (assoc 72 elist)))
          (zerop (cdr (assoc 73 elist)))
        10 11
      elist
;; Original from Lee Mac
(defun c:beam ( / ss1 ss2 in en pt i ) (vl-load-com)
  (princ "\nSelect Beam Text: ")
    (and
      (< 1 (length in))
    (repeat (setq i (sslength ss2))
      (setq en (ssname ss2 (setq i (1- i)))
            pt (trans (LM:GetTextInsertion (entget en)) en 0)
m4rdy
« Reply #10 on: April 25, 2011, 12:01:22 PM »
Hi M4rdy,
  (entmakex
  (cons 40 10.)
  (cons 41 10.)
  (cdr
    (assoc
        (and
        10 11
      elist
    (and
      (< 1 (length in))
Thank you very much, Lee Mac.
Now, It's done very well.
m4rdy
« Reply #11 on: April 25, 2011, 12:06:16 PM »
You're welcome M4rdy, happy to help you along the way  :-)
