Author Topic: Delete arcs from pline - lisp request  (Read 4697 times)
ziele_o2k
« on: March 30, 2017, 07:46:10 AM »
Could someone help me with lisp that will delete  arc segments from pline like in attached image
ChrisCarlson
Re: Delete arcs from pline - lisp request
« Reply #1 on: March 30, 2017, 08:56:25 AM »
You can utilize the "decurve" function of pedit to perform this task.
« Reply #2 on: March 30, 2017, 09:11:14 AM »
I think decurve would give a result more like this:
« Reply #3 on: March 30, 2017, 09:27:26 AM »
Here's a quick one to remove bulges:
  1. (defun c:db (/ ss)
  2.   (if (setq ss (ssget ":L" '((0 . "lwpolyline"))))
  3.     (foreach pl (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
  4.       (entmod (mapcar (function (lambda (x)
  5.                                   (if (= 42 (car x))
  6.                                     '(42 . 0.0)
  7.                                     x
  8.                                   )
  9.                                 )
  10.                       )
  11.                       (entget pl '("*"))
  12.               )
  13.       )
  14.     )
  15.   )
  16.   (princ)
  17. )
« Last Edit: March 30, 2017, 12:11:31 PM by ronjonp »
ziele_o2k
« Reply #4 on: March 30, 2017, 09:59:44 AM »
As ronjonp mention, decurve will give another result.. And decurve is easy to achive.
« Reply #5 on: March 30, 2017, 12:48:35 PM »
FWIW, you can use FILLET (with zero radius) on the surrounding segments to obtain the desired result.
« Reply #6 on: March 30, 2017, 12:51:19 PM »
Should the new linear segments be tangent to the arc, or parallel to the surrounding linear segments?
For example, given the grey polyline, which of the following new vertices is correct, green or yellow?:
What if there are no surrounding linear segments?
ziele_o2k
« Reply #7 on: March 30, 2017, 02:04:56 PM »
Yellow one :)
Let's asume that first and last segment of pline are linear and arcs are always between two linear segments of pline.
I will write routine which will filter selection set, so only plines fitting to assumptions mentioned above will be proceed.
EDIT:
One more assumption, plines can't be closed
« Last Edit: March 30, 2017, 02:19:00 PM by ziele_o2k »
MSTG007
« Reply #8 on: March 30, 2017, 02:07:17 PM »
This is interesting... This happens more so than I think. lol.
Civil3D 2020
kirby
« Reply #9 on: March 30, 2017, 04:01:57 PM »
Assuming this is converting Horizontal (highway) curves into linear segments between Points of Intersection (PI's):
  • The tangent distance is always perpendicular to a radial drawn between the Arc centre and beginning point of circular curve (or ending point of circular curve)
  • For deflection angles (or curve delta angles) > 180 degrees, split the arc into two (usually equal) and process normally.
See:
https://en.wikibooks.org/wiki/Fundamentals_of_Transportation/Horizontal_Curves
ziele_o2k
« Reply #10 on: March 30, 2017, 05:28:48 PM »
One more assumption, pline bulges are always made with round command.
« Last Edit: March 30, 2017, 05:39:13 PM by ziele_o2k »
« Reply #11 on: March 30, 2017, 07:06:05 PM »
I wrote the following for fun as I enjoyed the challenge, but I believe you can obtain the same result from filleting the polyline with a zero-radius fillet.
  1. ;; Decurve  -  Lee Mac
  2. ;; Equivalent to applying a zero-radius fillet to a polyline with arc-segments
  3.
  4. (defun c:decurve ( / enx hed idx int lst ocs rtn sel )
  5.     (if (setq sel (ssget "_:L" '((0 . "LWPOLYLINE") (-4 . "<NOT") (-4 . "&=") (70 . 1) (-4 . "NOT>"))))
  6.         (repeat (setq idx (sslength sel))
  7.             (setq enx (entget (ssname sel (setq idx (1- idx))))
  8.                   hed (reverse (member (assoc 38 enx) (reverse enx)))
  9.                   ocs (cdr (assoc 210 enx))
  10.                   lst (lwv-ptb enx)
  11.                   rtn nil
  12.             )
  13.             (while (caddr lst)
  14.                 (cond
  15.                     (   (equal 0.0 (cdr (assoc 42 (car lst))) 1e-8)
  16.                         (if (not (and rtn (ptonline (cdar rtn) (cdr (assoc 10 (car lst))) (cdr (assoc 10 (cadr lst))))))
  17.                             (setq rtn (cons (assoc 10 (car lst)) rtn))
  18.                         )
  19.                     )
  20.                     (   rtn
  21.                         (if (setq int
  22.                                 (apply 'inters
  23.                                     (append
  24.                                         (list (trans (cdar rtn) ocs 1))
  25.                                         (mapcar '(lambda ( a b ) (trans (cdr (assoc 10 a)) ocs 1)) lst '(0 1 2))
  26.                                        '(nil)
  27.                                     )
  28.                                 )
  29.                             )
  30.                             (setq rtn (cons (cons 10 (trans int 1 ocs)) rtn))
  31.                             (setq rtn (cons (assoc 10 (car lst)) rtn))
  32.                         )
  33.                     )
  34.                 )
  35.                 (setq lst (cdr lst))
  36.             )
  37.             (while (and (cadr lst) (ptonline (cdar rtn) (cdr (assoc 10 (car lst))) (cdr (assoc 10 (cadr lst)))))
  38.                 (setq lst (cdr lst))
  39.             )
  40.             (setq rtn (append (reverse rtn) (mapcar 'car lst)))
  41.             (if (entmake
  42.                     (append
  43.                         (subst (cons 90 (length rtn)) (assoc 90 hed) hed)
  44.                         (reverse rtn)
  45.                         (list (cons 210 ocs))
  46.                     )
  47.                 )
  48.                 (entdel (cdr (assoc -1 enx)))
  49.             )
  50.         )
  51.     )
  52.     (princ)
  53. )
  54. (defun ptonline ( pt1 pt2 pt3 )
  55.     (equal (distance pt1 pt3) (+ (distance pt1 pt2) (distance pt2 pt3)) 1e-8)
  56. )
  57. (defun lwv-ptb ( lst )
  58.     (if (setq lst (member (assoc 10 lst) lst))
  59.         (cons (list (assoc 10 lst) (assoc 42 lst)) (lwv-ptb (cdr lst)))
  60.     )
  61. )
Grrr1337
« Reply #12 on: March 30, 2017, 07:49:48 PM »
Damn Lee was faster, as always!
Leaving here my unfinished, failed attempt:
  1. (defun test ( / e o L pL int nL eL )
  2.   (setq e (car (entsel)))
  3.   (setq o (vlax-ename->vla-object e))
  4.   (setq L (vl-remove-if-not '(lambda (x) (eq "AcDbLine" (vla-get-ObjectName x))) (vlax-invoke o 'Explode)))
  5.   (setq pL (mapcar '(lambda (x) (mapcar 'vlax-get (list x x) '(StartPoint EndPoint))) L))
  6.   (setq int (mapcar '(lambda (a b) (apply 'inters (append a b '(())))) pL (cdr pL)))
  7.   (setq nL
  8.     (vl-sort
  9.       (apply 'append
  10.         (mapcar
  11.           '(lambda (a)
  12.             (mapcar '(lambda (b / p) (setq p (vlax-curve-getClosestPointTo a b)) (list (distance p b) b p a)) int)
  13.           )
  14.           L
  15.         )
  16.       )
  17.       '(lambda (a b) (< (car a) (car b)))
  18.     )
  19.   )
  20.   (repeat (length L)
  21.     (setq eL (cons (car nL) eL))
  22.     (setq nL (cdr nL))
  23.   )
  24.   (mapcar
  25.     '(lambda (x / p o)
  26.       (setq p (caddr x))
  27.       (setq o (cadddr x))
  28.       (cond
  29.         ( (equal (vlax-get o 'StartPoint) p 1e-2) (vla-put-StartPoint o (vlax-3D-point (cadr x))) )
  30.         ( (equal (vlax-get o 'EndPoint) p 1e-2) (vla-put-EndPoint o (vlax-3D-point (cadr x))) )
  31.       ); cond
  32.     ); lambda
  33.     eL
  34.   )
  35. )
And another way to achieve Ron's result:
(setq n (vlax-curve-getEndParam o))
(repeat (fix n)
  (vla-SetBulge o (setq n (1- n)) 0)
); repeat
Indeed this task is interesting!
(apply ''((a b c)(a b c))
vevo.bg
Sivaprasad
  • Mosquito
« Reply #13 on: December 10, 2023, 06:17:47 AM »
defun c:decurve
Please anyone post a LISP routine to decurve the fillets with condition (Decurve if the radius within the prompted units. Large radius do not need to change) in all polylines in a selecionset.
xdcad
« Reply #14 on: December 10, 2023, 11:51:23 AM »
defun c:decurve
http://www.theswamp.org/index.php?topic=58864.0
https://github.com/xdcad
https://sourceforge.net/projects/xdrx-api-zip/
http://bbs.xdcad.net
