Code Red => AutoLISP (Vanilla / Visual) => Topic started by: cadmoogle on November 21, 2008, 09:50:46 AM
CAB,
As I sit here and type with tremendous lag. Would it be possible to build a counter like you did with this command for the one Wizman built for the dangler lisp
http://forums.cadalyst.com/showpost.php?p=22905&postcount=11
If needed I could ask Wiz, but I wasn't sure if he would know what I was talking about.
I ran the command on 11901 objects and I'm not sure how much counter I have to go. You spoiled me with that counter on BreakAll :-D.
Thanks in advance
Counters are easy.
Initialize the counter to 0.
Update the counter within the loop.
Here is the loop.
(foreach dang_final_pt ronnil3
(command "._insert" bname dang_final_pt "" "" "")
) ;_ end_foreach
No more time this morning. 8-)
Wizman has added the feature to his code.
http://forums.cadalyst.com/showthread.php?p=22955#post22955
Topic closed :)
